SC- 1st Gen (1992-2000)
Wheel/Tire size
Old 04-20-11, 09:22 PM
ALLWiTE2JZ
ALLWiTE2JZ's Avatar
Default Wheel/Tire size
Old 04-20-11, 09:35 PM
SChema
SChema's Avatar
Pretty straight forward fitment, will clear stock body just fine.
F: 245/35
R: 275/30
Old 04-20-11, 09:51 PM
ALLWiTE2JZ
ALLWiTE2JZ's Avatar
Old 04-20-11, 10:03 PM
SChema
SChema's Avatar
Look at the pictures with the red lips in the first post in the attached link. They were +35 all-around on NF210's as well when those images were taken. Not quite your specs but it gives you an idea.
F: 18 x 8.5 +35 245/40
R: 18 x 9.5 +35 275/35
https://www.clublexus.com/forums/sc-...ld-thread.html
Old 04-20-11, 10:17 PM
SChema
SChema's Avatar
Managed to dig up some images of fitment from the front and rear view.
Front:
Rear:
Old 04-20-11, 10:20 PM
ALLWiTE2JZ
ALLWiTE2JZ's Avatar
Old 04-20-11, 10:22 PM
ALLWiTE2JZ
ALLWiTE2JZ's Avatar
Old 04-20-11, 10:26 PM
SChema
SChema's Avatar
Correct, NF210's.
Offset wise, your wheels will sit closer to the strut by 3mm all-around. In other words, your wheels will be 3mm less flush compared to those in the images.
Same suspension, I think what may have happen was I had the wheels off the car and back on without letting the suspension settle. So it was a tad higher in the two images attached. The ones from the other thread was the final height.
Old 04-20-11, 10:27 PM
ALLWiTE2JZ
ALLWiTE2JZ's Avatar
Old 04-20-11, 10:40 PM
SChema
SChema's Avatar
Virtually? No, it's not going to be noticeable. However, you will find yourself looking into spacers down the road to push them out a bit.
The farthest I got with those wheels were 5mm spacers in the front and 8mm in the rear. Resulting a 30 in the front on factory fenders and 27 in the rear with aggressively cut fenders.
I think you'll be able to push the fronts another 7 - 10mm easily, considering you're on NF210's (they don't drop dramatically, only about an 1 inch). The rears, I think you may be able to get away with a 5mm spacer if you choose to run 275 tires.
Old 04-20-11, 11:21 PM
SChema
SChema's Avatar
Miss read the original post for 18's. Please disregard those tire specs. They should be:
19's F: 245/35
19's R: 275/30
18's F: 245/40
18's R: 275/35
My appologies.
DIM
IS F (2008-2014)
09-15-11 03:40 AM
Blacky
IS F (2008-2014)
08-13-11 01:07 PM
poorbong
IS F (2008-2014)
12
07-22-11 10:43 PM
poorbong
IS F (2008-2014)
01-28-11 02:36 PM
ming15237
IS F (2008-2014)
06-06-10 06:46 PM
Quick Reply: Wheel/Tire size
