Wheels offsets
Tech Info Resource
Mechanically ideal or aesthetically ideal? There's a big difference.
If you don't want to shave/roll/mod your fenders, you will have to run these offsets with these tire sizes:
FRONT
WHEEL WIDTH OFFSETS WIDTH OF TIRE
7.0 +16/+65 225
7.5 +22/+65 225/235
8.0 +29/+59 225/235/245
8.5 +35/+52 235/245/255
9.0 +41/+46 245/255/265
REAR
8.0 +26/+65 225/235/245
8.5 +33/+65 235/245/255
9.0 +39/+65 245/255/265
9.5 +45/+65 255/265/275
10.0 +52/+65 265/275/285
10.5 +58/+60 275/285/295
I got this chart from Discount Tires.
Hope this helps.
FRONT
7.0 +16/+65 225
7.5 +22/+65 225/235
REAR
Hope this helps.
Tech Info Resource
And let's not forget the Enkei PF01s in an 18x9.5 +45 with 285s on all four corners with no trimming or shaving required.
Tech Info Resource
Best mechanical offset is the same as factory - it will give you the longest wheel bearing life. Anything else will shorten it.
FRONT
7.0 +16/+65 225
7.5 +22/+65 225/235
REAR
Hope this helps.
FRONT
7.0 +16/+65 225
7.5 +22/+65 225/235
REAR
Hope this helps.
