97 SC400 p/s problem
Old Apr 14, 2011 | 03:23 PM
threeputt2's Avatar
threeputt2
Default 97 SC400 p/s problem
Guys,
Car has been garaged for 2 years and this newbie is trying to get it back to being road worthy. Discovered today that p/s system had actual p/s fluid in it so I drained the system and filled it with Dexron III ATF. Prior to replacement there was moderate squealing which I was able to lessen significantly by the normal extreme turning from left to right and back. After replacement with ATF it makes an awful screaming squeal and requires extreme effort to steer. Turning back and forth doesn’t help. Wondering if p/s pump may be bad or if I did something really stupid when replacing fluid.
Any way to check that the pump is or is not functioning? Don’t want to purchase replacement pump only to discover that existing pump is OK and I definitely am not experienced enough to rebuild the pump.
Thanks,
ThreePutt2
Old Apr 14, 2011 | 04:05 PM
scottys209's Avatar
scottys209
Sounds like it's time..... How many miles on it? Did you flush the whole system or just drain the reservoir?
Old Apr 14, 2011 | 06:11 PM
HEWJsc4's Avatar
HEWJsc4
Keep in mind that you may have to bleed it for quite a while. When I fixed my PS pump leak I had to bleed it for a good 25 minutes before it was quiet.
Old Apr 14, 2011 | 07:35 PM
xspsi6's Avatar
xspsi6
What method did you use??
Dx3
Jun 25, 2014 11:47 AM
Farino81
Jan 25, 2012 03:52 PM
Vector
Dec 22, 2004 08:27 AM
VSsc400
Jun 10, 2004 05:07 PM
