higher volume vs higher psi?
Old Apr 10, 2011 | 10:42 PM
broda805's Avatar
broda805
Default higher volume vs higher psi?
currently im at 338hp @ 9psi on a borg warner s362 .81 a/r turbine side pretty much stock everything. tuned via aem ems
what do you other guys that run single think about running a bigger higher flowing compressor wheel vs raising the boost?
getting a tt head gasket installed later and wanted to up it around maybe 15-17psi (i think thats safe on a tt headgasket on pump gas right? lol) with some 550 injectors and new fuel pump etc.
since its going to be all apart anyways i was thinking what if i swapped in one of the 66 wheels instead of the 62 for more flow.. but retain the smaller turbine side for spool time. not trying to max anything out so i doubt it will hinder top end
thoughts? will it be significantly more laggy?
cost isnt going to be an issue gonna be a hookup so thats not a factor.
Old Apr 11, 2011 | 04:28 AM
lexforlife's Avatar
lexforlife
15-17 psi on tt hg is more than safe .. im at 19psi pure pump gas and we saw zero knock .. my advice is get cams .. it will allow the head to breath and you would be surprised at 17 psi what kinda of power your car will make.. at 14 psi my car did just under 500 rwhp and at just touching 19 psi it did a easy 592
stay with .81 hotside .. ,68 is too small for a 2jz it will choke the turbo and create too much backpressure which adds wear to motor .. let it breath and get some cams
Old Apr 11, 2011 | 08:21 AM
broda805's Avatar
broda805
Are cams for the gte the same for the ge motor?
Old Apr 11, 2011 | 08:24 AM
lexforlife's Avatar
lexforlife
no sir very different .. you would have to remove your cams and send them to web cams to ave them reground after they cold weld them to the proper specs..
ge have the gear on ex side for dist pickup gte uses a sensor in the head to pick signal
Old Apr 11, 2011 | 10:39 AM
broda805's Avatar
broda805
how much $ does that run? cheaper then some bc cams i hope? ~600$
Old Apr 12, 2011 | 07:47 AM
99SC42's Avatar
99SC42
I am getting mine done by these guys they are really good, and very reliable.
These guys charge $145.00 per cam, you can't beat their price.
Like ED said the cams will make it easier for you and i am glad to see you are running w/o any issues, and you didn't waste your time on stock 2jzge ecu and safc because it's garbage.
http://schneidercams.com/naturallyaspirated-5.aspx
Old Apr 12, 2011 | 07:53 AM
TLDriver's Avatar
TLDriver
Cams... I still haven't slapped mine in because I am missing some caps.
Old Apr 12, 2011 | 07:04 PM
lookEVO's Avatar
lookEVO
turn up the boost and get a meth kit maybe. lots of good things have been said about meth and Ive used it on lots of my cars
Old Apr 12, 2011 | 07:19 PM
broda805's Avatar
broda805
145/ea dont sound bad at all i'll have to call them and get some more info and let me know how it turns out for you.
i guess i gotta go hunt for a some cheap stock cams i cant have too much downtime as this is my only car
.. and probably need to start looking for a r154 as well
Old Apr 14, 2011 | 08:25 PM
TLDriver's Avatar
TLDriver
I got some 2jz stock cams.. I have them at the shop on the Ave. Let me know and I can bring them over to Oxnard.
Old Apr 14, 2011 | 08:27 PM
TLDriver's Avatar
TLDriver
even if you don't need/want my cams hit me up. I have someone that needs his AEM tuned in his SC300. Wondering if your buddy is able to do it.
Old Apr 15, 2011 | 09:28 AM
broda805's Avatar
broda805
pm'd ya,
any input on switching the compressor wheel to a 66?
SCott300
Jan 30, 2017 12:14 PM
CatManD3W
Dec 8, 2015 06:44 PM
mecheng10
Jan 23, 2014 09:43 AM
97sc300t
Apr 23, 2010 06:38 AM
