Help! Parking lamp problems
Old Nov 28, 2010 | 01:12 AM
rpk2012's Avatar
rpk2012
Default Help! Parking lamp problems
Okay, I am extremely tired right now so excuse me if I missed it during my search.
My parking lamps have never worked since I purchased my car. I thought it was the bulbs and I would get to them one day, BUT I did a resto on my drivers side housing today and while out I checked the bulb. It was good, so I checked the connector for power just to double check everything, and nothing. (from the harness side pigtail). I searched and searched for parking lamps and could not find a fuse, or wiring info on this.
Any ideas?
ALSO, side question. On the fuse box, is the sc300 and 400 kick panel boxes the same? Because I found a picture of my missing panel, and I do not have 3 of the fuse positions on lower rt. And one last question, why do I have an obd fuse port with no fuse, and power to the lead?
THANKS!
Old Nov 28, 2010 | 08:25 PM
rpk2012's Avatar
rpk2012
bump?
tencharacter
Old Nov 29, 2010 | 04:48 PM
rpk2012's Avatar
rpk2012
No one can assist me? No ideas?
Old Nov 30, 2010 | 01:59 PM
rpk2012's Avatar
rpk2012
BUMP for Visibility
Old Nov 30, 2010 | 02:13 PM
MMCtuner's Avatar
MMCtuner
Parking lights? Where are they located?
Old Nov 30, 2010 | 02:32 PM
rpk2012's Avatar
rpk2012
The parking lamps are next to your projectors, its that plastic tube looking thing.
Old Nov 30, 2010 | 02:50 PM
MMCtuner's Avatar
MMCtuner
Ah, ok. Sorry, I speak spanish and in some cars the parking lights are not the same as those.
Did you test if the connector works? If you are putting led lights, you must know that they work only in one way, so try that too.
Old Nov 30, 2010 | 05:30 PM
rpk2012's Avatar
rpk2012
I started with a test light, then used a voltmeter on both sides (LH & RH) and it had zero power to either connector. Then I looked for blown fuses, and a parking lamp fuse, and nothing.
Old Nov 30, 2010 | 06:35 PM
NEbiker10's Avatar
NEbiker10
Check ur relays
Old Nov 30, 2010 | 06:46 PM
rpk2012's Avatar
rpk2012
Which relays would control that?
Old Dec 1, 2010 | 07:21 PM
rpk2012's Avatar
rpk2012
Thanks a ton.......
for everyone with this Issue, it was with the side marker diode issue. Replaced with proper diode, and all worked amazingly. PM me if you need the diode type and part number.
Old Mar 8, 2011 | 02:55 AM
fleecer's Avatar
fleecer
where is the diode? i have one out too. pass side.
Dai Kaiju
Sep 1, 2025 01:14 PM
MikeBig
Mar 30, 2015 08:51 AM
joshoowa
Jan 17, 2013 02:27 PM
SCott300
Dec 27, 2011 11:19 AM
Boostshakalaka
Jun 21, 2006 06:20 PM
