Timing Belt - 92 SC400
Old Aug 1, 2002 | 01:12 PM
sunny76g's Avatar
sunny76g
Default Timing Belt - 92 SC400
Hey guys...
Does anyone know if the 92Sc400 has an interfering type Timing belt ?? I have 76500 miles on my SC and it runs great. Should I get the Timing belt changed.
Thanks for the help...
Old Aug 1, 2002 | 01:46 PM
jwTR6's Avatar
jwTR6
It is non-interfering (at least my 94SC4 is). I have 135K on my original belt but am having it changed in a week. I see from reading the posts here that 90K is quite acceptable for the belt.
Old Aug 1, 2002 | 03:04 PM
Lex Luthor's Avatar
Lex Luthor
90k is a reasonable interval to change the belt, but yes they are non-interference.
-LL
Old Aug 1, 2002 | 04:25 PM
pcmw's Avatar
pcmw
Any of the cars in this list with the * next to them are interference designs..... This is the best list I could find.
http://www.ourautoshop.com/timing.html
Old Aug 9, 2002 | 10:57 AM
sunny76g's Avatar
sunny76g
Thanks for the Info....
Old Aug 10, 2002 | 10:25 PM
Neal Rikal's Avatar
Neal Rikal
hmm how much for one of those there belts?
Old Aug 11, 2002 | 07:34 AM
carnal_c30's Avatar
carnal_c30
check www.nopi.com i believe their price is 42 bucks or so
Old Aug 11, 2002 | 12:51 PM
boredguy77's Avatar
boredguy77
not to sound dumb but what is interference? I have never heard of it!
Old Aug 11, 2002 | 03:21 PM
Lex Luthor's Avatar
Lex Luthor
boredguy, simply put, that means that there is no possibility that if the timing belt snapped, a piston(s) won't come in contact with an open valve as it approaches Top Dead Center. See, without a timing belt, the engine now has no way of knowing when to start opening and closing valves in relationship to the position of the pistons in their respective bores, so when the belt snaps, the reciprocating assembly is still spinning, but the valvetrain is no longer coordinated with it, and with an interference design a piston could wack a valve, and something's gotta give, you'll bend some valves or pop a hole through a couple of pistons, either way it's ugly. To give you an example, the well-known 5.0 litre Ford 302 (it's actually 4.9 litres, but that didn't look as good on the fender) is not only an interference motor, but it is notorious for lack of piston-to-valve clearance, i've warned guys to 'clay' to check for clearance when building these motors, but some don't listen and wind up finding out the hard way. Clear enough?
- LL
Old Aug 11, 2002 | 09:12 PM
boredguy77's Avatar
boredguy77
ok that makes sense sorry to make you type a whole lesson, but if it helps, I appreciate it. thanks alot.
WDoherty
Aug 17, 2007 10:08 PM
Tez
Nov 2, 2006 05:38 PM
Redskns92
Jul 31, 2006 09:23 AM
MarkMacGS4
Maintenance
Aug 8, 2002 11:40 AM
GSquicksilver
Maintenance
May 16, 2002 07:23 PM
