Start up issue.
92 SC400 1uz-FE
I replaced the Water pump and timing belt, before i changed them the belt was fine and the Water pump was just leaking a little. So the engine fired up and i was able too drive. So i went ahead and took her apart and replaced. Now everything is back together except i haven't put coolant fluid or engine fan fluid in yet. I try too start her up and i can hear a couple exhaust notes coming from the back but she wont start? I checked the grounds, cleaned spark plugs, can even smell gas. Checked all my fuse's and made sure i plugged all vacuum lines, and wire cables in. Anyone have any idea what could be wrong?
Do you actually have any spark? Pulling the high tension lead and holding about a half inch gap while someone cranks should produce nice fat sparks.
Also, is the battery fully charged? Sometimes there's enough amperage to crank the engine, but not enough actual voltage to trigger the ignition.
Just trying to throw out some ideas. I hope you get it sorted out.
-=Photon=-
-=Photon=-
-=Photon=-
-=Photon=-
Bought a new battery, she deffinitly turns over fast enough now. She is sputtering out the exhaust, everything sounds right. Onlything i noticed weird was the doors locking and unlocking as i try too start. I think there might be some kind of electrical issue, anyone have a clue?
I don't have the problem you have, but it still sounds like a timing issue. I found this post in case it is of any help to you:
https://www.clublexus.com/forums/per...-on-sc400.html
Thank you, i posted on that link. Hopefully this can get resolved. Been over a month since any progress. I am 99.9% sure its not the timing, its set exactly too what the service manual said. Is there some wire or something that might make this happen if not properly plugged in? Everything seems normal except my electrical.
winky
Jan 17, 2014 09:13 AM
95SC400
Dec 28, 2004 09:16 AM
