HELP!!!Required Bits and Pieces for M90/1UZFE
It might be out there, but the only thing i found was this http://www.richwoodaero.com. For those who have done this install whats needed since the supercharger is +/-200 bucks. What else would i need??? Im not gonna go all crazy but just basic, i gotta have some supercharger whine in my life!
Please dont flame.. If theres a thread i couldnt find it..
Product Name:
Lexus 1UZ-FE Supercharger
"Semi-kit" Suit Eaton M90 (Ford).
Product Number:
LX 100110
Product Cost:
AUD$2995.00 or USD$2250
Product Description: Our semi-kit is designed for the tuner in mind. The semi-kit contains all components necessary to install your supercharger:
* Manifold and top plate
* Rear intake
* By-pass valve
* Pulley and spacers
* Belt and intake gasket
* Mounting hardware and fitting instructions.
Customer to Supply: Supercharger and rising rate fuel regulator.
So they're saying that they will provide everything you need to get the supercharger on there and making boost. You just need to determine what you want to do with fuel and tuning.
Product Number:
LX 100110
Product Cost:
* Rear intake
* By-pass valve
I ran a Richwood just get the semi kit. I have some m90 parts if you need them but not a complete i rebuilt one with another... You will also need to make a bracket to hold your cables i believe you need to extend the throttle one to if i remember correctly. Oh and i had to run new fuel lines i could not get mine to fit at all and you lose your cold start injector unless they have changed it since.
thanks fellas.. my situation is I WANT BOOST before i get rid of my car. The problem is being able to afford the semi kit is a little hard when unemployed.. Im guessing richwood is the only company that makes the kit huh?
No there are some others but Richwood is the least expensive i believe. Why do you want boost right before you get rid of your car?
i should have been more specific lol.. I meant i want to boost it, and keep it.. rather then not boost it, got bored, and get rid of it.. Its like a girlfriend doing the same thing in bed everynight.. when they change it up you fall in love with it again.. lol
Well at 5-6psi the car is def quicker but when a souped up turbo neon or something blows by you. You will be like WTF!
