TT head swap ?
Old Oct 6, 2010 | 03:31 PM
SC300_704's Avatar
SC300_704
Default TT head swap ?
i'm pretty sure this has been cover many times but i couldn't find the right answer i'm looking for. so a buddy of mines is gonna let me have his 2jzgte head for free so i figure i might put it on my n/a block..i know there's a thread about it on supra forums but what i wanna know is what exact/complete parts do i need to get this swap done besides turbo related stuff?
here's what i know so far that is needed:
complete tt head (cams, intake mani, injectors, etc.)
tt oil pump
several sensors?
will probably go aem ems
thermostat housing
tt ignitor
coilpacks
tt engine harness or can i modify the n/a to work?
usdm heater hose
usdm oil cooler..is this necessary?
lmk what i'm messing....
Old Oct 7, 2010 | 09:38 AM
99SC42's Avatar
99SC42
Water pump is different, you will need the Upper radiator pipe.
Thermostat and housing is the same.
Modify the Na harness and make it work.
Upper radio hose.
Aftermarket oil cooler.
Old Oct 7, 2010 | 09:49 AM
stockhatch's Avatar
stockhatch
I wonder if it is even worth the hassle. The GE head seems to flow as well if not better than the TT head in some instances...
Old Oct 7, 2010 | 10:52 AM
99SC42's Avatar
99SC42
Well some people do it for the intake manifold and Intercooler routing , i think it's worth it if you can do it yourself and you can get the parts for Free or great deal.
I like them both..
Old Oct 7, 2010 | 10:55 AM
stockhatch's Avatar
stockhatch
Oh yeah, I didn't even consider the intake related stuffs.
Old Oct 7, 2010 | 10:57 AM
YeA 2jZ's Avatar
YeA 2jZ
also the trans GE trans works differently than a GTE trans and to get the GTE head to work on ur GE block ur gonne need the GTE ecue which in turns controls the trans
Old Oct 7, 2010 | 11:19 AM
99SC42's Avatar
99SC42
He is thinking about going EMS so no worries, if you are manual it doesn't matter really but it you are auto that's when the fun begin because the GTE ECU can't control the GE Auto Tranny.
So that's when AEM is needed.
Oh yeah the ugly A$$ distributor lol, i am so glad i didn't have to worry about that thing.
Old Oct 7, 2010 | 11:23 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
^^ right.. messing with the crank and cam sensors was so much more fun than using the poor ol distributor... haha you know im playing i would ditch the dizzy in a second but it is reliable!!
Old Oct 7, 2010 | 11:30 AM
99SC42's Avatar
99SC42
Ali some people don't care about the way their engine bay look, so the distributor doesn't bother them they just use a screen on the front of the Turbo which i don't like .
I like the 4" or 5" pipe in front and Filter on it lol , that's just me like the clean look.
I will keep pushing you till we delete that thing lol, and yeah it's been good to you but it has to go haha.
Old Oct 7, 2010 | 12:36 PM
99SC42's Avatar
99SC42
Oh yeah i forgot you will need a new TT oil pump and crank gear.
Old Oct 7, 2010 | 05:32 PM
SC300_704's Avatar
SC300_704
Upper radio hose.
hopefully the harness isn't as hard as some people say to modify and as for the oil cooler, is it really needed? since the ge head don't have a oil cooler can i run w/o a oil on the gte head or is it required?
Old Oct 11, 2010 | 12:30 PM
99SC42's Avatar
99SC42
The Harness is not bad if you run the VVti coil Setup.
The oil cooler is on the block not on the Head, I would run an aftermarket oil cooler.
Old Oct 11, 2010 | 12:51 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
+1 save yourself alot of money and time and go vvti coilpacks with a dh61 or ds62 ignitor. 61 is from the vvti 2jzge and the 62 is off a camry both do the exact same thing (3 channel wasted spark ignitors). the best thing is they are much cheaper than a TT setup and the coilpacks are more reliable + less wires to run.
with the TT coils + aem you will need a DLI or ignition amplifier.
with the vvti coils + aem you are already done,
Old Oct 11, 2010 | 03:52 PM
SC300_704's Avatar
SC300_704
^^ thanks! that helps a lot.
Old Jul 31, 2011 | 05:16 PM
soarer13oy's Avatar
soarer13oy
I maybe going this route since im getting a knock. I really cant afford a gte block right now so would i be able to basically put the gte head on the ge block and call it a day? I basically have all the gte parts. Would i even need to modify my harness? OR would it be recommended to keep the block and put in new bearings and a used crank?
