project:Soarer
Old Aug 20, 2012 | 10:48 AM
  #346
projectm's Avatar
projectm
hmmmmmmmm!
Old Aug 20, 2012 | 08:28 PM
  #347
cartmill's Avatar
cartmill
so what boost are you hitting, and what AFR is it running at full boost/load ?
Old Aug 21, 2012 | 06:30 AM
  #348
megamax's Avatar
megamax
a. downpipe isn't complete so i don't have a proper reading from the jump
b. i had both ports plugged on my wastegate. hence why i think i didn't get a good full or boost at all.
i should be able to try this again properly on monday.
Old Aug 21, 2012 | 06:44 AM
  #349
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Lets get this car runing and hitting some boost.. Like no feeling in the world, well besides.................................................
Old Aug 21, 2012 | 08:33 AM
  #350
cartmill's Avatar
cartmill
c. i should be able to try this again properly on monday.
a. you shouldn't drive it with no downpipe on it.
b. if your wastegate ports were both capped it wouldn't open at all. you need to go research how turbo systems work -- wastegates in particular.
i guess your post means you couldn't get into boost?
c. you mean try it properly for the first time
put the downpipe on, install the wideband (calibrate it if necessary), watch the boost gauge.
Old Aug 21, 2012 | 08:46 PM
  #351
Vrank's Avatar
Vrank
.63 a/r is equivalent to roughly an 8 or 9 cm housing, so considering it's half the size, then yes. it should spool quickly.HY35 and HE341/351 are 9cm housings, and are kick *** mild street turbos. Yanked the **** out of an 07 mustang gt with programmer and full exh and other boltons last night running a tad rich at 11.5psi from like a 30 roll.
listen to cartmill, his advice here is gold
Old Aug 30, 2012 | 03:24 AM
  #352
megamax's Avatar
megamax
Default The verdict
well i finally got around to testing how much god hates me. the moment of truth....
the "warmed up engine" compression test.. and heres the numbers.
------------------------------back of engine------------------------------
6- 170
5- 175
4- 175
3- 175
2- 180
1- 180
--------------------------front of engine----------------------------
This is such A big relief knowing now i have a excellent healthy engine. Now it's on to more mods/tuning/lsx killings!!
__________________
Old Aug 30, 2012 | 06:51 AM
  #353
cartmill's Avatar
cartmill
why are you compression testing?
Old Aug 30, 2012 | 08:16 AM
  #354
kez's Avatar
kez
Is she running right now or is the turbo the actual problem
Old Aug 30, 2012 | 03:41 PM
  #355
megamax's Avatar
megamax
compression testing because i want piece of mind this engine isn't a piece. it idles between 15.2-16.1 afr.
and still getting exhaust put together. help me fix my window.
Old Aug 30, 2012 | 05:02 PM
  #356
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Status of the wastegate and DP?
Old Sep 10, 2012 | 06:33 PM
  #357
megamax's Avatar
megamax
so, where was i???? oh yea!!!
so i got the car running and noticed some poo looking liquid in the wastegate and lightly coated around the inside of the exhaust tubing. the wet **** looked like this..
and further more in the wastegate itself.
so iam thinking "holy ****" the damn turbo is eating my oil. i did noticed some of the oil was slightly missing when i ppulled the dipstick. mind you i wasn't running the engine for too long.
so i tracked down a restricter.
then i remembered the seller telling me that they did put some crap in the cylinders to keep corosion away due to it being around the salt water. and come to think of it. i did see some liquid stuff in some of the cylinders when i was inspecting it last year.
But a buddy of mine was convinced it was my valve seals. hence why i did my "hot" compression test.
looking at this wet cylinder thinking it was also the valve seals too(till the poo stopped).
so as of now there is no more poo just condensation from a healthy engine. and seems that my oil level is consistant now.
Old Sep 10, 2012 | 06:37 PM
  #358
megamax's Avatar
megamax
so cleaning that poo up. i cracked open my cheapo wastegate. the mechanics are really simple. which now i can understand how even the cheapo ones work without a hitch..
oh wait!!! spoke too soon. see the hairline. but dosen't look like it will be a problem for now. will have to remove and take to an aluminum welder to get patched up. will prob do that when i get a better spring. don't know how many psi this one is. but iam guessing around 6-8(very sad).
http://i1062.photobucket.com/albums/...crackisbad.jpg
Old Sep 10, 2012 | 06:41 PM
  #359
megamax's Avatar
megamax
so, finally got around to springing for a new damn windshield!!! It's great to be looking out a brand new one that isn't cracked/pitted
so the deal with my driver side window??
finally got that fu#k$r to work!! seems the button is shorted. and needs to be pressed down hard and at an angle for the window to to up. so pulled the door for nothing!!
But
but
but..
This has to be the *****test door panels ever made. they are so cheap and have no screw support. iam verry dissapointed lexus skimpped out on these when the damn car fetches 50k new.
Old Sep 10, 2012 | 06:44 PM
  #360
megamax's Avatar
megamax
so right now me and a buddy of mines that welds are fabbing up a exhaust for this. not easy at all and very tedious.
heres what the downpipe looks like now. it's seen better days. but it's just a measuring,cut,weld job. that i hope to finish this week.
in other news. i was running really LEAN last week when i recirced my wg tube into my exhaust(like 21 afr). iam running the stock fuel pump. so i ordered a wally and it should be here tomorrow.
and i got a aero-fpr on the way this week with some lowering springs. stay tuned.
