Can i beat a.......?
Old Jun 28, 2002 | 08:48 PM
  #31
lex400sc's Avatar
lex400sc
Originally posted by Mistical
Who has a new body syole CL or TL with a 100,000 + miles on it? Is that even possible? And......who would race any car with less than 1,000 miles on it any way.
He was talking about the 1992 SC300, not the 2000 TL. It is very possible to have 100,000 miles on a 2000 car. Toog, I don't know about 0.5 seconds, but the rule applies to ALL cars.
Old Jun 29, 2002 | 09:00 AM
  #32
SC300T's Avatar
SC300T
Its not a set number of miles... Depends on many factors. I personally feel that at 100k, most engines are starting to get alot of gunk in the engine and compression is starting to go down due to wearing of the cylinder bores/ valves not perfectly seating anymore...
I would guess most engines are in their prime around 30-60k miles.
Engines with closer tolerances will have a more noticeable improvement after break-in than engines with loose tolerances.
Old Jun 29, 2002 | 10:51 AM
  #33
Silver00Spike's Avatar
Silver00Spike
my infiniti j30 has 186k miles, so what ure saying is when i hit 200k miles(if i dont sell it by then), my 0-60 time should drop by a FULL second! WHOOOHOOOOOO!!!!
Old Jun 29, 2002 | 11:08 AM
  #34
Neal Rikal's Avatar
Neal Rikal
cost effective?...........ha! this is starting to sound like an infomercial. im getting nausiated. lets try $4000... its this whole don't be a schmuck and pay the going rate to a major company for a turbo. work your sources and get the same parts cheaper and install them yourself. its this whole money saving deal.
Old Jun 29, 2002 | 12:23 PM
  #35
SC300T's Avatar
SC300T
when my car had 90k on it, it went 15.2.
when it had 115k on it, it went 13.4
when it had 130k on it, it went 12.7
now that its got 150k on it, It should be in the mid 11s.
Its amazing how well its broken in.
Old Jun 29, 2002 | 12:26 PM
  #36
the_ez_rhino's Avatar
the_ez_rhino
Can someone please explain how you choose when you shift gears in an automatic?
Jason
Old Jun 29, 2002 | 12:40 PM
  #37
SC300T's Avatar
SC300T
You always want to use all the rpm you have on an SC300.
Shift L-2-3-4 with the gate.
There will be a delay in the time when you shift from L to 2, 2-3, 3-4, to the time the tranny actually acomplishes the shift so you have to play around with it and shift in to 2 when the tach is near the redline, but before it. Otherwise, you'll bump the limiter. Just keep the shift point at the highest point without hitting the fuel cut. This will give you the best time. The fuel cut is a few hundred rpm past the redline. Hitting the rev limiter a few times isn't going to hurt the engine either, these things can rev to 7500rpm with the stock valvetrain and can do 8500-9000rpm with upgraded valve springs.
On our GS400, I have to initiate the 1-2 shift at 5200rpm to avoid fuel cut at 6300rpm, so you may have to initiate the shift significantly early, especially in the 1-2. It all depends on how fast your tranny shifts.
Old Jun 29, 2002 | 02:07 PM
  #38
the_ez_rhino
So for fastest 0-60 time I want to get as close to redline as I can without feeling a cut in fuel? Should I do that in every gear when racing? Or just in 1st, going in to second?
Jason
Old Jun 30, 2002 | 09:18 PM
  #39
Toog4me's Avatar
Toog4me
Fuel cuttoff??? Is that when you floor the car and their is a brief delay and nothing happens, then you feel the engine kick in, or is that just the engine changing gears?
MrDank757
Mar 10, 2014 12:20 AM
vegas_sc4
Jan 26, 2011 10:07 AM
LexusFTW
Oct 28, 2005 10:37 AM
J J
Dec 26, 2004 09:07 AM
KCLARK
Jul 13, 2001 10:27 AM
