need help with brake caliper tool
Old May 15, 2010 | 06:45 PM
antnice333's Avatar
antnice333
Default need help with brake caliper tool
i got a sc4oo 93 but idk which tool to get or if theres a cheaper way of doing so?
thanks
Old May 15, 2010 | 06:58 PM
masagsxr's Avatar
masagsxr
What are you trying to do? your question isn't clear...
Old May 15, 2010 | 07:04 PM
antnice333's Avatar
antnice333
to reset the calipers do i just get a tool if so ca i just get any old brake caliper tool
Old May 15, 2010 | 07:06 PM
good2go's Avatar
good2go
I don't even know where to begin
Old May 15, 2010 | 07:10 PM
antnice333's Avatar
antnice333
man im use to a ford and i could just use pliers to reset them and i want to know if i have to wait til next pay check to get some fancy tool or is there another way
Old May 15, 2010 | 07:13 PM
Sup2jzgte's Avatar
Sup2jzgte
use a c clamp
Old May 15, 2010 | 07:16 PM
antnice333's Avatar
antnice333
i just broke one, bent the handle off, so is there a problem with my caliper or a ****y clamp?
Old May 15, 2010 | 07:20 PM
Sup2jzgte's Avatar
Sup2jzgte
Lets just make sure we are talking about the same thing here. You want to compress the piston correct?
If you just broke a c clamp trying to compress one of the pistons it is either
A) all the way down
B) Seized in there and your options are to replace the entire caliper or fight with the piston to get it out and rebuild them.
Old May 15, 2010 | 10:18 PM
good2go's Avatar
good2go
Ahh...I gottcha now. I couldn't figure wtf you were talking about when you said "reset the calipers"
SO, did the piston move at all when you tried with the clamp? I guess (and you hope) it could be a bad clamp. Maybe you tried to tighten it too fast and the handle tweaked; it's good to tighten it slowly to give time for the piston to return. I have sometimes used a pair of heavy duty, screwdriver sized pry bars, opposing each other in back-to-back fashion and pressed against either of the old shoes; then I just force the bars together until the shoes have fully seated the pistons back into the calipers.
But, as the previous poster said, if they won't move at all, 'A)' and 'B)' are pretty much your options. G/L
Old May 16, 2010 | 07:05 AM
SH_JZZ30's Avatar
SH_JZZ30
Try loosening the bleed screw when pushing the pistons in. I've used a c clamp and the old brake pads.
Old May 16, 2010 | 09:32 AM
t70 supra's Avatar
t70 supra
what i did was
take the top of where u put the brake fluid in use a C clamp and a small piece of wood to compress both pistons
Old May 16, 2010 | 02:31 PM
StiCk3's Avatar
StiCk3
you had to do something pretty nasty if you broke your C-clamp on a caliper. i dont think your using it right....and you don't need to pop the bleeder screw open, i used a set of wide vice grips and walk the piston back in.
Old May 20, 2010 | 12:29 AM
xx69xx's Avatar
xx69xx
If you broke a c clamp you got 1 of two things a seized piston or collapsed line. An easy way to tell is by opening the bleeder screw and if the piston compresses easily then you have a bad line simply replace line and bleed. If it doesn't you need caliper. And just to be safe replace the other sides calipers and do brake flush all at once.
Old May 21, 2010 | 12:08 AM
ToyotaMike's Avatar
ToyotaMike
I was able to use 2 screw drivers to pry back the pistons on a 4runner today so if you need more force then that you need a rebuild or replacement. Be sure to take the cap off your brake fluid reservoir so the fluid can easily travel back into it as your pushing the pistons back.
wsrivers
Jan 16, 2018 12:52 PM
Speedy0o
Sep 24, 2017 09:40 AM
john689089
GX - 1st Gen (2003-2009)
Mar 24, 2016 11:36 AM
shivam
May 17, 2013 06:28 AM
lexus-is2
Suspension and Brakes
Apr 30, 2013 08:02 PM
