Caliper Piston
Old Apr 30, 2013 | 02:57 AM
lexus-is2's Avatar
lexus-is2
Default Caliper Piston
When changing brake pads, the DIY's here say to use a clamp to push the piston back. I notice dirt stuck onto the caliper so i used brake cleaner to clean it off, but wondering does the piston need to be lubricated in any way? as it needs to be able to freely move back without getting stuck and cant seem to see any greese or lubration material on the caliper piston. Someone suggested to me that applying some brake fluid with a brush around the edge of the piston will help, is this correct?
Old Apr 30, 2013 | 05:23 AM
BernieIS's Avatar
BernieIS
The only way you would have to lubricate the piston is if there is no movement when you press on it with a clamp.
Old Apr 30, 2013 | 03:21 PM
jleeIS's Avatar
jleeIS
Maybe I'm reading this the wrong way, but I've never had to lubricate the piston as it's mostly covered by a rubber boot. I've cleaned around it to make sure no dirt gets into the system, but never had to lubricate anything.
Old Apr 30, 2013 | 05:50 PM
Gville350's Avatar
Gville350
I've never rebuilt a caliper before, but I believe behind the cylinder seal there is lube to keep it mobile. And no, you don't want any debris to get on the cylinder because it is possible when it contracts back inside the caliper bore that it gets trapped back in behind the seal. When after a while it might develop a notch in the cylinder or bore, thus causing sealing issues.
Old Apr 30, 2013 | 08:02 PM
Denver's Avatar
Denver
no need to relube it because theres already brake fluid in there..... but you should flush the system to prevent the pistons from seizing and damaging seals.
Pnoy619
CL of Southern California
May 25, 2012 03:04 PM
thejanitor
RX - 1st Gen (1999-2003)
Apr 14, 2012 06:28 PM
sung35
Suspension and Brakes
Feb 18, 2006 05:59 PM
T0ked
Maintenance
Oct 2, 2004 07:45 PM
lexsc3
Wheels, Tires & Brakes Forum
12
Mar 21, 2004 08:21 PM
