SC- 1st Gen (1992-2000)
AC light blinking
Old 05-09-10, 07:02 PM
Dx3
Dx3's Avatar
Default AC light blinking
Guys,
Trying to help someone with AC issues. Does AC light blinking mean the AC sensor relay is bad? I tried searching but AC doesn't work on the 3-character search requirements...
Thanks,
Jonny
Old 05-09-10, 09:05 PM
6SOARER
6SOARER's Avatar
Not sure if this applies to the SC but it may help:
https://www.clublexus.com/forums/per...eed-codes.html
Old 05-10-10, 06:10 AM
Dx3
Dx3's Avatar
Very interesting read as I didn't know any of this stuff - but unfortunately doesn't help answer my question. Thank you though.
Jonny
Old 05-10-10, 08:06 AM
aka paco
aka paco's Avatar
when i got my 03 camry recently the AC was working fine then one day it quit and the AC light kept flashing.. on those cars a common issue is the AC clutch relay goes bad and you have to replace the relay..
think the relay was labeled "AC MG" or "AC MC" and it was a relay in the fuse box in the engine bay, either way don't know if our cars ever have a similar issue but i was able to replace it with a $15 dollar relay from autozone and it has worked great since..
Old 05-10-10, 08:13 AM
Dx3
Dx3's Avatar
Hey man - I have read about this a lot, but it seems that it is common to the ES/Camry and is a magnetic clutch relay. Not sure if the SC's use those or not... I will tell him to give it a shot though. Thanks for your help,
Jonny
Old 05-10-10, 10:57 AM
lemaylexus
lemaylexus's Avatar
Compressor isn't turning on. Check in the owners manual in the A/C section, it will describe what is happening to you. Chances are you'll need a new compressor.
jay169
GX - 1st Gen (2004-2009)
07-14-17 12:36 PM
dsls400
Performance & Maintenance
01-02-15 09:51 PM
D.K.
Maintenance
07-28-04 02:02 PM
dj.ctwatt
03-10-04 12:32 PM
Quick Reply: AC light blinking
