Solid Subframe/Diff Bushings
Old Apr 28, 2010 | 10:25 AM
ConSynX's Avatar
ConSynX
Default Solid Subframe/Diff Bushings
It seems a lot of people went custom to get there...Someone help me by making a second set please.
The closest I got to finding a solution were these threads:
https://www.clublexus.com/forums/sus...entioning.html
https://www.clublexus.com/forums/sus...-bushings.html
There's others, but it appears PBM, Battle Ver, and Titan are the options.
I don't much care for PBM's design, it doesn't change the fact that my bushings are shot.
Battle Ver would be awesome, i'm waiting to hear back about potential availability.
Titan would be expensive, and i'm doubting the ability for Supra Subframe and Diff mounts to work with with SC300 Subframe + Diff.
*edit* for clarification. Battle Version makes Solid Subframe Bushings, FSM Makes Solid Differential Bushings.
Hopefully someone will just pop in here with the nice solution and save me countless more hours of searching.
Now if only my engine problem was as common (revs drop to 1700 then hang up for a bit).
Thanks
Old Apr 28, 2010 | 12:47 PM
ConSynX's Avatar
ConSynX
Wow, FSM and Battle Version were quick to reply to the messages I sent them. I've been okayed to post their messages
FSM:
Hi Steve,
Yes the diff bushings are always available and in stock. You can call to place the order with a credit card, or send paypal +4% to sales@fsmoto.net
Price is $200 plus shipping.
Some of our other popular branded products are our forward facing intake intake manifold kits, billet NA fuel rails, billet ford style to oem tps adapters, egr block-off plates, solid shifter tri-pod bushings, and more.
Dan Hartnett
President
First State Motorsports
www.FSMoto.net
A picture of their product
Battle Version:
"Yeah, I have them[subframe bushings]. Email me your zip to alex@battleversion.com, they are $175 plus shipping. The front ones are easy to change out but the back ones, you need to burn the rubber out of the mount, then put the aluminum ones in."
He also mentioned only making a few, not sure if these are something he plans to continually make or not.
SuperPro apparently makes polyurethane bushings for most of these as well.
Old Apr 28, 2010 | 05:13 PM
Pipe's Avatar
Pipe
sorry for the noobie question but where does that go? , how hard is it to put in and do you have pics ?
Old Apr 28, 2010 | 05:38 PM
good2go's Avatar
good2go
lol "I don't even know what it is . . . but I want one!"
Old Apr 28, 2010 | 07:31 PM
Dan@FSM's Avatar
Dan@FSM
Here's a pic of the FSMoto bushings installed
Sorry for the blurry pic. This one shows what separates this design from the others that are available. Other's replace the bolt and don't use the OEM washer that is shaped to the factory bushing, where these bushings have extra machining detail to use the factory washer to help spread the load evenly across the whole bushing to reduce the chance of galling.
Old Apr 28, 2010 | 08:59 PM
Pipe's Avatar
Pipe
Thanks for that,so we just keep the factory washers and replace the rest with theses bushings. So I figure that this reduces wheel hop?
Old Apr 29, 2010 | 02:28 AM
the3rd's Avatar
the3rd
The price seems a bit a high but the other bushings you have to cut.
Old Apr 29, 2010 | 03:47 AM
fleishelja's Avatar
fleishelja
I interested, whats the benefit here, what are we going to feel more of now that there will literally be no dampening of the diff?
Old Apr 29, 2010 | 07:20 AM
RedPhoenix's Avatar
RedPhoenix
Might hear more diff noise, but a lot of cars I rode in with solid subframe/diff really wasnt that much more rough or anything since the suspension arms and driveshaft have rubber bushings on them too. It does reduce wheel hop, a mod on my to do list.
Old Apr 29, 2010 | 07:25 AM
BattleVer's Avatar
BattleVer
The subframe spacers I have are for the subframe, not the diff mounts like in the picture. Seems like the FSMoto mounts are different then the ones I have. Here are a couple pics of what I have,
Spacers by themselves.
How they fit in the rear mount.
And how it looks on the subframe,
If you look at that last picture, you can see the forward aluminum spacers in the subframe for the front subframe mounts.
Old Apr 29, 2010 | 05:43 PM
Pipe's Avatar
Pipe
What is the benifits of using those? My guess is to reduce wheel hop and give the the suspension a bit more rigidity.
Old Apr 29, 2010 | 06:48 PM
good2go's Avatar
good2go
^^ reduces drive train losses too
Old Apr 30, 2010 | 12:39 AM
Pipe's Avatar
Pipe
Dang why are my pay checks taking soo long?!? Lmao I want some Now!!!
Old May 3, 2010 | 10:12 PM
BigWaveSC's Avatar
BigWaveSC
good thread, I was about to buy the titan ones but only because I didnt know anyone else made them.
Old May 4, 2010 | 12:07 AM
Vincent123's Avatar
Vincent123
how much do the battle version subframe spacers cost???
