SC- 1st Gen (1992-2000)
viper 5901 install
Old 12-26-15, 08:57 PM
  #31
megamax
megamax's Avatar
video is up...
Old 12-27-15, 06:53 AM
  #32
gerrb
Super Moderator
gerrb's Avatar
Originally Posted by megamax
you have instructions from a different viper model. I have the 5706v yours is the 5901
I have a
10 pin
24 pin
and a 6 pin
Now I see why you got different instructions, lmaol. I assumed you had the 5901 since this thread is about the 5901.
I am sorry Jim, I doubt I can be of further help since I don't have experience on the 5706v. A wrong advice from my end can cause damage and even set your car on fire since those wires you are asking about are high amperage wires.
Old 12-27-15, 11:13 AM
  #33
megamax
megamax's Avatar
well I think it's related in terms of did you use relays when wiring up starter and ignition wires?
Old 12-27-15, 11:21 AM
  #34
gerrb
Super Moderator
gerrb's Avatar
starter wires where straight in and out of the module
One of the ignition wire / relay has to go straight to the module because you want the system on even with the ignition off
Old 12-27-15, 11:23 AM
  #35
SSmith
SSmith's Avatar
Go to my build page and start on page 22. The viper alarm you are installing is built by DEI which is what I installed. Most of your wire locations and matching wires can be found on pages 22-24
Shane
Old 12-27-15, 01:07 PM
  #36
megamax
megamax's Avatar
Shane
okay cool, thanks shane. did you or g happen to use a relay? when I call best buy or any other shop they say "you need a relay' but I see other threads where it's not needed?
Old 12-27-15, 03:52 PM
  #37
gerrb
Super Moderator
gerrb's Avatar
Jim - I used a relay for the trunk release.... but relay is not going through ignition so trunk can be opened by the remote without key on the ignition.
Old 12-28-15, 07:31 AM
  #38
megamax
megamax's Avatar
so to make that work, would I need to run the trunk trigger or trunk release output?
Old 12-28-15, 07:09 PM
  #39
gerrb
Super Moderator
gerrb's Avatar
yes sir ...
Old 01-02-16, 07:42 PM
  #40
megamax
megamax's Avatar
so I have 2 wires left did you find the tach on a sc400 before g? the diagrams say they are behind the pass strut tower but nada..
and there are 2 wires going to the trunk key, which one did you go with? thanks sir!
Old 01-03-16, 06:58 AM
  #41
megamax
megamax's Avatar
Originally Posted by scviolence
1.)im starting to think this damn wire does not exist....lol...i found one wire that was green with lil grey tac marks on it...and they flashed on with the unlock/lock feature ....when i turned the car on they didnt stay on.. then i found a green and yellow wire and a green and black wire..green and black the left signals front and rear flashed green and yelloe the right signals flashed...tried both together fuse blew lol....idk....
2.)this worked like a charm
trunk relay bosch style 30 amp 4 prong relay..3.99
contact 85 - Trunk pop output (h1/1 red/white)
contact 86 - 12v constant
contact 30 - ground
contact 87 - Trunk release wire from switch (black on 2 pin connector from switch)
do you mind if I can get some pics of this?
Old 01-04-16, 04:34 AM
  #42
gerrb
Super Moderator
gerrb's Avatar
Easiest place to tap on the tach is from the connectors / wires near the ECU or from the igniter .
The trunk trigger is tapped on a wire on the driver side running board. It is a wire that goes to the release solenoid of the trunk. If I remember right on the SC it is a red / white wire...
BananaGS
08-18-21 01:06 AM
scviolence
20
04-29-10 01:12 PM
lexus4jess
GS - 1st Gen (1993-1997)
10-06-08 06:27 PM
tritron
04-16-07 06:41 PM
DaBling69
01-09-03 06:26 PM
Quick Reply: viper 5901 install
