Remote Starter Wiring Colors and Notes
Lexus
GS 300
1995-1998
Function
Vehicle Color
Location
Start:
BLACK/BLUE
IGNITION SWITCH HARNESS
Ignition #1:
BLACK/ORANGE
Ignition #2:
BLACK/YELLOW
Ignition #3:
N/A
Accessory:
YELLOW
Brake Light:
GREEN/WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK
AT IGNITER ON PASS. STRUT TOWER
Parking Lights:
GREEN/RED (+)
# PIN CONNECTOR AT FUSE BLOCK *
Headlights:
RED/BLACK (-)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
RED/BLACK (-)
IN DRIVER KICK PANEL
OEM Alarm Arm:
BLACK (-)
# PIN BLUE CONNECTOR
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
Lexus
GS 300
1995-1998
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
PINK/GREEN & WHITE
Starter Kill:
BLACK/BLUE
Ignition +12 Volts:
BLACK/ORANGE
Dome Lights/Superv:
RED/GREEN (-)
OEM Horn:
GREEN/WHITE (-)
STEERING COLUMN HARNESS
Power Lock:
WHITE/RED
# PIN BLUE CONN. IN DRIVER'S KICK **
Power Unlock:
BLACK/WHITE
Trunk Release:
WHITE/BLACK (-)
AT TRUNK RELEASE SWITCH ***
Alarm Input Wire:
RED/GREEN (-)
Notes:
* Fuse Block Located In Driver Kick Panel. ** Child Safety Locks- BLUE/ORANGE (-) In 9 Pin Connector In Driver Kick Panel. See Note #209 - Toyota Child Safety Locks Diagram. *** See Note #232 Negative Pulse Door Lock Diagram.
Remote Starter Wiring Colors & Alarm and Keyless Entry Wiring Colors
Lexus
GS 300
1995-1998
Function
Vehicle Color
Location
Start:
BLACK/BLUE
Ignition #1:
BLACK/ORANGE
Ignition #2:
BLACK/YELLOW
Ignition #3:
N/A
Accessory:
YELLOW
Brake Light:
GREEN/WHITE (+)
Tach Signal:
BLACK
Parking Lights:
GREEN/RED (+)
Headlights:
RED/BLACK (-)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
RED/BLACK (-)
OEM Alarm Arm:
BLACK (-)
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
Lexus
GS 300
1995-1998
Function
Vehicle Color
Location
Constant +12 Volts:
PINK/GREEN & WHITE
Starter Kill:
BLACK/BLUE
Ignition +12 Volts:
BLACK/ORANGE
Dome Lights/Superv:
RED/GREEN (-)
OEM Horn:
GREEN/WHITE (-)
Power Lock:
WHITE/RED
Power Unlock:
BLACK/WHITE
Trunk Release:
WHITE/BLACK (-)
Alarm Input Wire:
RED/GREEN (-)
Notes:
on my 93 gs300 to disarm the factory alarm you have to pulse negative to the thin red wire at the ignition. You can test this by hooking up one end of a light probe to positive and then the other end to the red wire, when you stick your key in the ignition the light should go off. Looking at the schematic thats the only way to do it on my car, the only way the alarm can be turned off is either with the ignition switch or by opening the doors. A side effect of this is that after remote starting the car you have to remote lock the doors to turn the factory alarm back on. Also the - black - lock wires and -black/yellow- unlock wires can also be found on the theft deterrent ecu under the dash on the driver side, its just really hard to get to the wires. Last thing, the factory hood open switch is the red/green wire at the theft deterrent ecu.
tunanaut
06-25-15 04:07 AM
