noOb needs help
Old Mar 29, 2010 | 07:40 AM
mysoarer's Avatar
mysoarer
Default noOb needs help
i've recently replaced my sc4's engine and now i cant get it to crank, i've tried jumping the starter relay and doesnt work either. as far as i know i got everything hooked up. i've searched and found the anti theft deal but thats not it. all my grounds are hooked up as i double checked it. the dash lights goes dim as i go into start position, my battery is good also. thanks for you time, any help will be apreciated
Old Mar 29, 2010 | 08:58 AM
Dx3's Avatar
Dx3
What happens when you jump the starter relay? What exactly is happening? Just the dash lights dimming? Does it crank? Does it click? If yes, just once or repeatedly?
More information is needed.
Jonny
Old Mar 29, 2010 | 11:23 AM
mysoarer's Avatar
mysoarer
I dont think i got power to the relay, i just jumpered it with out the relay and still nothing. no clicks. i guess i might have to check out the ignition switch or something maybe?
Old Mar 29, 2010 | 12:11 PM
Dx3's Avatar
Dx3
By jumping the starter you are already bypassing the ignition switch so I doubt that is it. Get out your voltmeter and trace your positive wire from the battery to your fusebox etc and see where you lose power.
Did you remember to plug your ECU back in?
Jonny
Old Mar 29, 2010 | 06:26 PM
mysoarer's Avatar
mysoarer
the first time i didnt have the ecu pluged in but i got ecu in already
Old Mar 29, 2010 | 07:13 PM
Dx3's Avatar
Dx3
Then it is time to start tracing where your power is going... Seems like there is something not plugged in...
Jonny
Old Mar 30, 2010 | 06:08 AM
mysoarer's Avatar
mysoarer
i have a feeling something is not pluged in but all the stuff i double checked is in, i geuss i gotta take out the meter. i'll let you know what i come up with if i can find it.
Old Mar 30, 2010 | 06:59 AM
Dx3's Avatar
Dx3
There are very few plugs that would remove power from your entire car. I would revisit your ECU and make sure there are no issues there. Not sure what else could keep power from ENTIRE car. All your ground straps reattached?
Jonny
Old Apr 1, 2010 | 06:41 AM
mysoarer's Avatar
mysoarer
its been raining where i'm at, looks like i might have a chance on sunday to work on the problem.
Old Apr 1, 2010 | 11:41 AM
1jzchris's Avatar
1jzchris
hey are you sure you starter is good.If you jump the starter no matter what it will still turn over, it just wount start.
Old May 24, 2010 | 05:44 AM
mysoarer's Avatar
mysoarer
i've finally got off my lazy *** to take another shot on fixing the car. i've manually jump the starter with no luck. with the key on the dash lights are all funtioning fine but when in crank posistion it gets dim with without cranking. i've noticed that the fuel pump does not turn on when i turn the key on. hopefully some one here got a idea of what plug i'm missing or something because i've looked over and over and i'm really getting frustrated
Old May 24, 2010 | 07:26 AM
fleishelja's Avatar
fleishelja
It sounds like you have a starter issue. if everything else is working and I'm assuming all your fuses are good then it should have no reason to not crank or at least try to turn. In all my years working at lexus ive never seen an sc with a bad ignition cylinder. and seeing that you just put a different engine in it. The lights dim because of a load, so either you have high internal resistance in your starter wire harness or you have high resistance in the starter. the car started before you put the engine in it right, well that mostly rules out the relay, and possibly the harness unless you just replaced that as well.
Old May 24, 2010 | 07:27 AM
fleishelja's Avatar
fleishelja
you also wont hear the fuel pump running all the time in the on position and the car not running, it only builds pressure to get the car started and then starts to run in the crank position and when it sees a crank signal and in the on position.
Old May 24, 2010 | 09:59 PM
mysoarer's Avatar
mysoarer
yeah it started before i did the engine change, and as for the pump i dont not hear it prime at all with the key on not even the first time after a night of sitting.
Old May 27, 2010 | 01:45 AM
mysoarer's Avatar
mysoarer
.......still looking for loose connections with no luck.
