need help to remove oil pump so i can replace main seal
Old Mar 4, 2010 | 06:25 PM
SC300_704's Avatar
SC300_704
Default need help to remove oil pump so i can replace main seal
so far i got all the bolts off, all necessary pulleys removed and the engine is also raised up by a engine hoist..i tried to pry it off (moved just a little) but backed off b/c i'm afraid i might break something. don't tell me i'm gonna have to take the upper oil pan off to do this? i tried cutting it like the manual says but that front seal material is kinda hard to cut.
Old Mar 4, 2010 | 06:37 PM
Dx3's Avatar
Dx3
We just did this and we took the upper oil pan off...
Jonny
Old Mar 4, 2010 | 06:49 PM
SC300_704's Avatar
SC300_704
someone from supraforums just told me that i could use a screw driver to push on one side and the other side should start coming out..i'll try it tomorrow to see if it works. btw did ya have to remove the water pump for this?
Old Mar 4, 2010 | 07:07 PM
Dx3's Avatar
Dx3
I was replacing the motor in a 96SC300. The motor I had was from a 93 and didn't have the crank angle sensor. So basically pulled the bottom of the motor off to replace the oil pump. We already had the WP off so I don't know if it is required or not. Ask LexusFTW - that boy knows his stuff
Jonny
Old Mar 4, 2010 | 07:09 PM
soarer13oy's Avatar
soarer13oy
i used a knife to cut the rubber piece and then put paper on to of a falt head and popped it out. i doubt you have to take the water pump out. i too mines out because i was replacing it aswell. Btw i did this is on a gte. Never took the oil pump out.
Old Mar 4, 2010 | 07:39 PM
SC300_704's Avatar
SC300_704
excellent! on my manual it gives you a picture for where to cut but can't really understand it..does it matter where you cut it?
Old Mar 4, 2010 | 08:25 PM
StiCk3's Avatar
StiCk3
anywhere away from the crank, should you slip and scratch up the crank, the seal may not last long. Just be careful to not pry on the edges of the oil pump too much.
My co-worker had a special tool that basically was a mini pry bar with a razor blade on the end of it. Get's it out quickly all the time, gonna try that on my 1jz this weekend.
Old Mar 4, 2010 | 08:58 PM
1sxyrxy's Avatar
1sxyrxy
wait what?? your pulling your pump off to change your FMS?
Old Mar 4, 2010 | 09:30 PM
snomanlex's Avatar
snomanlex
For that I used a flat head with electrical tape on the end and rubber hammer and hit one side till the other came up. When the other side of the seal came out I just pryed it lightly and it was all set. No oil pump removal, or waterpump. If the seal is in poor condition it will actually crack as you hit it and will eventually just crumble and fall out. If you can get the right angle you can actually hit the flat head into the seal and actually pull out the seal. Just be careful with the oil pump edges as someone stated and the crank.
Attached Thumbnails need help to remove oil pump so i can replace main seal-2010-03-05-00.20.10.jpg   need help to remove oil pump so i can replace main seal-2010-03-05-00.20.36.jpg
Old Mar 5, 2010 | 07:43 AM
SC300_704's Avatar
SC300_704
thanks fellas!
Old Mar 5, 2010 | 01:52 PM
soarer13oy's Avatar
soarer13oy
You cut on the inner portion of the seal. ITs rubber so cutting it would be pretty easy, then you pry it out. Let us know how it goes.
Old Mar 5, 2010 | 08:14 PM
SC300_704's Avatar
SC300_704
got it out, i just used a screw driver and hammer it.
faulks2
Jul 10, 2018 02:39 PM
amlarajr01
Feb 7, 2018 08:18 AM
megamax
Feb 20, 2014 08:36 AM
Xaolin
Aug 21, 2012 11:24 AM
O. L. T.
Nov 20, 2011 11:35 AM
