Key has trouble going into trunk hole.
Subscribe
Mar 3, 2010 | 09:43 PM
Never had this problem until recently I decided to open my trunk using my key. I had trouble getting the key into the hole and when I got it in the hole, I had it trouble getting it back out, almost got stuck. I am afraid of putting lube inside the key hole because I am not sure if it is okay to do so. Is there a way to fix this problem?
Reply 0
Mar 3, 2010 | 09:46 PM
maybe just spraying the key with wd-40 and working it back and forth?
Reply 0
Mar 3, 2010 | 09:53 PM
sounds like the inside of the key hole is dirty or something? try doing what ashtray said first... but i don't think putting lube inside the key hole will do any damage either.
Reply 0
Mar 3, 2010 | 09:56 PM
try messing/removing and reinstalling the lock on the tail light. It has a little lever on that connects to something and i think thats what makes the trunk open
Reply 0
Mar 3, 2010 | 09:58 PM
either wd-40 or some good old graphite. You can get graphite from any lock smith supply store and the stuff does wonders for lock cylinders.
Reply 0
Mar 3, 2010 | 10:22 PM
your putting it in the wrong hole
sorry I had to say it
the graphite is the best bet its made for locks i'd go that route
Reply 0
Mar 4, 2010 | 01:23 AM
+3 on the WD40... worked like a charm
Reply 0
Mar 4, 2010 | 07:39 AM
I should do this. I have trouble getting my key in the driver side door when it's cold.
Reply 0
Mar 4, 2010 | 01:36 PM
I've got a similar problem with mine. Mine goes in, but wont turn. Do you guys think WD-40 would fix that as well, or should I pop the taillight out and have a closer look?
Reply 0
Mar 4, 2010 | 01:45 PM
wd-40 will work, but graphite is the ultimate solution seeing as how thats one of its specific purposes and is used by every locksmith I have ever known, and it will outlast the wd40 over time.
lemaylexus-I would suggest removing the taillight and see if there is something in the way, or bent that isnt allowing it to turn.
Reply 0
Subscribe
