problem with myprothane bushing kit
Old Feb 27, 2010 | 03:55 PM
t70 supra's Avatar
t70 supra
Default problem with myprothane bushing kit
i went to go have my bushings replaced as well as both my wheel bearings replaced, and we had 1 problem the bushings dont fit so i thought to my self they have been seitting in a corner y dont they fit. im like what the hell
so when went back to the shop and made a video my guy said ur not suppoosed to use the exsisting sleaves that the kit should have new ones
http://www.youtube.com/watch?v=LsPzMvezAGk
Old Feb 27, 2010 | 04:04 PM
FuMoFFuTT's Avatar
FuMoFFuTT
uh huh.. ?
Old Feb 27, 2010 | 05:49 PM
5sp_jzz30's Avatar
5sp_jzz30
the stock metal sleeve needs to be replaced. you need to burn out the old bushing or have right tools and a press to press it out.
i dont know if that sleeve can be purchased separately from the dealer. probably not and only as part of the whole control arm assembly.
you can buy sleeves together with the daizen bushing kits(prothane bushings). im sure they will sell you just the sleeves if you contact them.
Old Feb 27, 2010 | 06:14 PM
PEARL2's Avatar
PEARL2
on point, reuse the old sleeves. Today I installed the bushings and they fit well. Tapped them in with a rubber hammer. I had to cut one of the camber bolts to get the arm out, and in the process messed up one of my sleeves.
Old Feb 27, 2010 | 06:55 PM
t70 supra's Avatar
t70 supra
I'm still puzzled y they have so much room in the bushing.
Old Feb 28, 2010 | 08:06 AM
5sp_jzz30's Avatar
5sp_jzz30
because the sleeve is not there. isnt that the whole point of this thread? lol
here is what you need:
the metal sleeved in the top middle of the picture.
Old Feb 28, 2010 | 09:16 AM
t70 supra's Avatar
t70 supra
my old 1 is ruined
Old Feb 28, 2010 | 09:29 AM
YeA 2jZ's Avatar
YeA 2jZ
it depends on the kit you buy, I bought the protheane kit not the daizen one and it didnt bring the metal sleve which means i had to reuse the old on that is in there. I just changed mine on thursday and my tech almost made the mistake of taking out the sleve. If u ur mechanic pulled the whole sleeve out then ur stuck and are going have to buy a new one. Its not a must to change it just depends on the kit you buy thats why daizen offers two different kits when u do new bushings. But since urs are messed up from taking it out its too late
Old Feb 28, 2010 | 10:30 AM
SC300_704's Avatar
SC300_704
just did mines the other day, burn out the old rubber, clean the inside of the lca very well, lubricate the bushings w/ the grease that it came w/ and hand pushed it in..i don't recall any sleeves besides the ones that came off the aluminum inner sleeves which are to small to reuse...
Old Feb 28, 2010 | 06:00 PM
spdrcr771's Avatar
spdrcr771
I did the same thing dude. I pushed my inners out, then used a small bluepoint air hand hacksaw blade to cut the sleeve, got it out and realized my kit didnt come w/a new sleeve, i thought i was F'ed then someone came up w/an idea. so i went down to my local exhaust shop, digged around in his scrap bent till i found a pcs of exhaust tubing that my bushing fit, it fit good but bushing still would spin it the tube, once i tried to fit the pcs of pipe in the control arm it was just slightly too big. PERFECT, put the bushing in and pressed the pipe in with a press. sware its just like OEM never had a problem EZ fix. you cant buy the sleeve, just go get some exhaust tubing take you control arm to autozone or a exhaust shop, you'll find what u need. you only need like 5"
Old Mar 6, 2010 | 01:40 PM
MongooseGA's Avatar
MongooseGA
I reused my old inner sleeves. I feel as though they'd be a pain in the *** to take out anyway.
The problem I had with my bushing fitment was that they were too long to fit into the housing on the frame. I had to dremel a small amount off of the outer perimeter of the bushing itself to get it to fit in the bracket.
Old Mar 6, 2010 | 01:41 PM
t70 supra's Avatar
t70 supra
lock mods cars out of the shop
Old Mar 6, 2010 | 05:50 PM
SC300_704's Avatar
SC300_704
were we supposed to use the stock lca outer circle (washers?) things for the prothane kit b/c i didn't?
Old Mar 6, 2010 | 11:57 PM
FiSta's Avatar
FiSta
i was wondering the same thing because i also didn't...there was no way of getting them on the new bushings
bfigard
Jun 4, 2020 12:11 PM
the90zkid
Oct 4, 2010 02:02 AM
MAUFKNCED
Sep 3, 2010 01:40 PM
nthach
Oct 3, 2007 02:50 PM
Panerai127
Suspension and Brakes
20
Oct 26, 2006 07:30 AM
