performance chips
Old Feb 24, 2010 | 03:41 PM
SenorCasas's Avatar
SenorCasas
Default performance chips
does anybody have any recomendations on which performance chips work best on sc 400's. mine is a 1995. i want one that will adjust timing, fuel injection, rpm limit and speed limitations through flashing or replacing the eprom on ecu. input will be appreciated. thanks for your time and best regards
Old Feb 24, 2010 | 03:46 PM
GS FONZy's Avatar
GS FONZy
Uh, none... Standalone
Old Feb 24, 2010 | 04:38 PM
SC400TT's Avatar
SC400TT
I see you're real new. Welcome to the club. AS GS Fonzy stated: there are none. The Toyota ECu's cannot be flashed or modded. Either add an SAFC or some other piggy-back, a UniChip, or a stand alone.
Old Feb 24, 2010 | 04:42 PM
Anthony's Avatar
Anthony
lol +1......
Old Feb 24, 2010 | 09:03 PM
Mistahxken's Avatar
Mistahxken
Welcome to club lexus!!! Search is your friend! =d
Old Feb 24, 2010 | 09:33 PM
Luxor's Avatar
Luxor
There is already a performance chip installed from the factory and it turns on when you push ECT.
Old Feb 24, 2010 | 09:47 PM
GZZ-TT's Avatar
GZZ-TT
Get with ScottURNot he has a standalone wired for the 1UZ cheap
Old Feb 24, 2010 | 10:06 PM
GS FONZy's Avatar
GS FONZy
Wait what if you don't have that button? Anyone wanna trade? My SC's don't have that button
Old Feb 24, 2010 | 11:08 PM
JohnEd's Avatar
JohnEd
I installed a piggy back. If you haven't upogrfaded the cam exhaust duration and opened up the exhaust a bit ypu won't see much from a stand alone. The cam move should open you eyes but without it I think you are chasing your tail with some big bucks.
My pigy back is smog legal but there is a story. When you go to WOT you come off the closed lopop feed back engine control and drop into a open loop preprogrammed mode. Just like when you first start up a cold engine you get more power for the same reason. The piggy back lets you modify the mix at the WOT mode. In the factory program the mix at WOT is very rich. The piggy back actually lets you adjust the mix keaner for more power. All engines/cars being different, you need a dyno to find and program in that "sweet spot". I have this on good authority. Beside the Piggy Back you need za hour on a dyno for $400.
When I want power I am usualy at WOT but I can tel you that the power at "cold start" is really impressive for a few minutes and the kick is at all throttle settings.
There was a lot of discussion about installing a Supercharger and not messing with the ECU. Sounded far fetched but while the engine ran super lousy after installing the Super the darn thing "learned" the new system and after 50 miles or so had edialed itself back in to neck snaping performance with the exra charge. That data came from the Aussie guys that make the Super and I am sure they would like to sell you more stuff and it starts out scary....I am told.
Good luck,
John
Old Feb 25, 2010 | 11:57 AM
SenorCasas's Avatar
SenorCasas
Default Thanks all!
I brought the car up from Texas at roughly 650 feet above sea level and now I am here in Colorado at over 5000 feet and I miss the performance I had and wanted some back. Thanks again! If anybody has any suggestions on best bang for the buck for my vehicle, I am all ears.
From the new kid on the block
Old Feb 25, 2010 | 12:49 PM
SuperiorSC's Avatar
SuperiorSC
afc, emanage(i have one forsale ), or some sort of piggyback would be your best bet.
Old Feb 25, 2010 | 01:15 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
LOL
Old Feb 25, 2010 | 04:47 PM
SC400TT's Avatar
SC400TT
ROFL!! That button is useless!!
Ryan
skint agai
Oct 4, 2007 05:59 AM
JMparts
May 16, 2007 10:02 AM
valikaaar
Jan 16, 2007 11:01 AM
Lexy GS430
Sep 20, 2004 06:05 PM
Mullet
IS - 1st Gen (2001-2005)
Oct 28, 2003 06:01 AM
