Map ECU 2 or Emanage Ultimate?
Old Feb 3, 2010 | 02:57 PM
SC300_704's Avatar
SC300_704
Default Map ECU 2 or Emanage Ultimate?
so yeah i've read a lot of threads on clubna-t.com and other forums but i can't seem to find which one is best for me..so far i've talked to 2 shops around my area and one says emanage ultimate and the other says map ecu 2. i'm aiming for 450+whp w/ supporting mods of course. i was planning on getting the aem ems but decided not to b/c i'm poor like that.
Old Feb 3, 2010 | 02:58 PM
GSXRMack's Avatar
GSXRMack
I have ultimate and will give you an update when I actually start tuning with it.
Old Feb 3, 2010 | 03:03 PM
SC300_704's Avatar
SC300_704
awesome! i'm leaning towards the ultimate more b/c it can get rid of the maf but would hate to do the wiring. could the map ecu get rid of the maf to?
Old Feb 3, 2010 | 03:06 PM
GSXRMack's Avatar
GSXRMack
Before I did the 1JZ swap I was learning alot about how to go speed density with the GE ecu. Specifically the air meter. Its a Karmen vortex and runs off of Hz not volts. Check out the DSM site's jsut google Emanage ultimate and 300GT. They have a ton of experience with it.
That is exactly what the MAP-ECU was designed for. I forgot which was said to work better with OBD1 but if you have a good tuner that knows the MAP-ECU then you are good to go.
Old Feb 3, 2010 | 03:14 PM
SC300_704's Avatar
SC300_704
correct me if i'm wrong but from what i know so far if i were to go w/ the ultimate i would just need the actual box, universal harness, map sensor and the ignition harness or would i not really need the ignition harness?
Old Feb 3, 2010 | 03:23 PM
GSXRMack's Avatar
GSXRMack
There is a injector harness and a ignition chip but I am not 100% you need the ignition chip. I can sell you my injector harness for cheap as I dont need it on the 1JZ. And the universal harness. I bought a soarer specific harness. Its the 2.5 meter harness. Let me know man. Hit me with a PM.
Old Feb 3, 2010 | 03:47 PM
ogre's Avatar
ogre
you can delete the maf sensor with the map ecu 2. also has a crap load of additional features, which is y i went with it
Old Feb 3, 2010 | 05:16 PM
soarer13oy's Avatar
soarer13oy
Sorry not trying to thread jack, but im swapping an aristo motor soon. I have the usdm turbos and wanted to figure out what piggy back am i able to use to be able to control the injectors and eliminate boost cut.
Old Feb 4, 2010 | 04:17 PM
ogre's Avatar
ogre
i know map ecu2 has a built in boost cut controller, im pretty sure the emanage ultimate does too though
Old Feb 4, 2010 | 04:26 PM
soarer13oy's Avatar
soarer13oy
will getting either of those ekiminate boost cut from the stock twins? I want to run sequential if that makes a difference
Old Feb 4, 2010 | 07:11 PM
SC300_704's Avatar
SC300_704
after some hard thinking i'm probably gonna end up getting the map ecu 2 b/c there's a shop (RLZ) not to far from me that has experience w/ the map ecu 2. he also recommends the map ecu 2 over the emanage ultimate plus he has it on his tt supra.
Old Feb 5, 2010 | 12:00 AM
GSXRMack's Avatar
GSXRMack
Definitely go with something they can tune or have the most experience with. No since in being the guinea pig, with a blown motor.
EMU does boost cut. So thats a yes for both doing boost cut.
Sag
Nov 6, 2013 11:01 AM
tampa mike
Mar 24, 2012 07:12 PM
SC51
Apr 14, 2010 04:10 PM
VSsc400
Jul 6, 2006 12:32 PM
got_trd
Jul 28, 2005 09:57 AM
