Mines ECU
Old Apr 30, 2011 | 11:30 AM
Sag's Avatar
Sag
Default Mines ECU
I have SC300 with 1jz swap
on a donor car I had this Mines ECU,
Tried google and it gives few facts about it, not sure if those are correct.
Any benefits of that ECU ?
Want to raise boost up to 1 bar, using HKS EVC, for "emergency" moments.
Also read somewhere that I can use 550cc mk4 injectors with that ECU with out a problem, true or what ?
Old Apr 30, 2011 | 12:13 PM
drft_n_sc's Avatar
drft_n_sc
I believe you can contact Mines and they can give you all the specs on your ECU if you give them the serial number
http://www.mines-wave.com/
Hope that helps
Old May 1, 2011 | 06:20 AM
Sag's Avatar
Sag
That is not an option
too much to take apart to get that number.
Old May 1, 2011 | 06:37 AM
DoomLight's Avatar
DoomLight
i sure love to have one of those ecu's, they are hard to come across.
Old May 3, 2011 | 01:56 PM
shonuff53's Avatar
shonuff53
^agreed with Doom if you would like to get rid of it I'd sure be interested if it works
Old May 3, 2011 | 11:39 PM
Sag's Avatar
Sag
Whats the point of having it
if you dont know what it does.
Old May 4, 2011 | 04:41 PM
shonuff53's Avatar
shonuff53
all of them have the gay boost cut removed which gives you more room to fool around with a piggy back since voltage clamp wont be 4.3 and instead 5 volts. I don't know about everyone else but that and the rev limiter gone is just the kind of thing that would make me unstoppable with the piggyback I have.
Old Nov 6, 2013 | 11:01 AM
lonniep111's Avatar
lonniep111
do you want to sell the ecu?
stevegrizz
Aug 11, 2014 07:11 AM
grumpi300
Jun 28, 2012 04:17 PM
kikcaffine
Southeast
Mar 15, 2011 12:06 PM
Klaus
May 17, 2010 05:59 AM
