MAP ECU 3 assistance needed
Old Feb 17, 2012 | 02:35 PM
tampa mike's Avatar
tampa mike
Default MAP ECU 3 assistance needed
A friend dropped his 98 sc300 turbo off with me and asked me to get it running on his new map ecu3.
upon going through the setup screen I was not sure as to what to label his car as for the metering device? It had "map replacement" "HF KVX, TPS Y axis" and about 12 others in the drop down table. So I wasnt sure which one to use as he has removed the maf and it is running on the map ecu, map sensor.
I could have sworn that the OBDII SC300s were "hotwire" mafs, and the older ones like mine were a Karmen Vortex type maf.
Can anyone lend a hand here, it would be much appreciated
Old Feb 17, 2012 | 03:04 PM
Cleanshots's Avatar
Cleanshots
set it as the map ecu map sensor.. its a map sensor now.. so thats what its gonna use.. let me know how the mapecu3 is specs look good ill run it if its good
Old Mar 23, 2012 | 06:19 PM
Trevstuh's Avatar
Trevstuh
Any updates on how the map ecu 3 runs?
Old Mar 24, 2012 | 07:12 PM
tampa mike's Avatar
tampa mike
Vvti+obd2+map ecu equals pain in the ***! Talked with a few map dealers & what I got was "good luck" basically.
Map is gone, aem v2 is in.....done in 1 day
dubseven
Apr 9, 2015 10:47 AM
kauaian
IS F (2008-2014)
May 23, 2013 05:33 PM
SC51
Apr 14, 2010 04:10 PM
SC300_704
Feb 5, 2010 12:00 AM
2jzSC300TT
Feb 12, 2005 12:14 PM
