Biggu's engine refresher build thread.
Old May 9, 2012 | 01:20 PM
  #316
MIKU*SC3's Avatar
MIKU*SC3
Originally Posted by Biggu
damn right it is.
Nice, ive been wanting to get one and add a long tip to it.
I wanna hear it!!
Old May 11, 2012 | 06:00 AM
  #317
Biggu's Avatar
Biggu
car was on the dyno a few days ago with no luck. everything was fine, boost was good but for what ever reason the car is some kinda limiter that the car is hitting at 4700 RPM. regardless of what we do we cant get it to go away. we turned off the 2 step, checked the rev limiter, made sure the boost safety was raised but its still happening. I changed coil packs, sparkplugs, ignitor. I personally think that its a limiter in the ECU because its not boost related its rpm. even at idle it will hit it like a 2 step
anywhays heres a sound clip. sorry its on photobucket.
http://s18.photobucket.com/albums/b1...t=dbf08b37.mp4
http://s18.photobucket.com/albums/b1...t=9668fed1.mp4
Old May 11, 2012 | 08:13 AM
  #318
stockhatch's Avatar
stockhatch
Sounds good with those bumpy cams and exhaust Good luck getting the limiter issue ironed out.
Old May 15, 2012 | 07:03 PM
  #319
Biggu's Avatar
Biggu
So I literally think this is the post everyone has been waiting for... cam sensor is fixed and car hit the dyno today on high boost the car did 600 wheel and 654 TQ before 3700 RPM. sadly the turbo is outta steam which is shown by the torque numbers being higher than the hp and the wastegate seems to have issues controlling the power at that level so I need to start looking at twin wastegates.
anyways no video from the run since I wasn't there however my buddy captured it for me and should be sending me the video soon.
here are some photos of the new catch can setup. if you want any help making your guys setup like my contact the boys at Slowmotion Motorsports.
Cars quarters get finished up tomorrow and then it can come back to my place for final adjustments on the ride higth and then to alignment which will end at hanging body panels! hopefully soon ill get on to the track for a shake down run or two
Old May 15, 2012 | 09:57 PM
  #320
BAD954BOI's Avatar
BAD954BOI
Can't wait for the video!!
Old May 16, 2012 | 05:11 AM
  #321
stockhatch's Avatar
stockhatch
Very nice! Those are some really massive numbers down low, especially for how much cam you have. Congrats
Old May 16, 2012 | 05:42 AM
  #322
DoomLight's Avatar
DoomLight
pretty good numbers. im running a GT35r just like you if i am not mistaken. i should be in the same neighborhood.
Old May 16, 2012 | 09:09 AM
  #323
Biggu's Avatar
Biggu
yours will probably be quite a bit less than mine because my head built and my motor is a 1.5jz running e85. My 35r is a custom setup as well to get it the extra spool I wanted for my setup. all in all im super happy that the car did the numbers it did it went exactly as I planned it would.
Old May 16, 2012 | 05:19 PM
  #324
DoomLight's Avatar
DoomLight
True. Mine is still a 2.5 liter. I'm only gunning for 500hp. Still its good to see a GT35r making good power.
Old May 16, 2012 | 08:44 PM
  #325
1cleen1JZ's Avatar
1cleen1JZ
nice set up. gt30 and gt35 are my favorite turbos for nice street machines.
Old May 17, 2012 | 06:58 AM
  #326
94_soarer's Avatar
94_soarer
wooaaahhh, big juice!!!
Old May 17, 2012 | 08:28 AM
  #327
cartmill's Avatar
cartmill
biggu, you made 654tq before 3700rpm? damn! post a dyno graph.
what size hot side are you running?
Old May 20, 2012 | 05:53 AM
  #328
Biggu's Avatar
Biggu
Cartmil, Im still waiting on the shop to get me the dyno graph.
the hot side is a .84 twinscroll.
Here is a Video from yesterday on shakedown runs.
Old May 20, 2012 | 09:14 AM
  #329
stockhatch's Avatar
stockhatch
Nice! Are you Tater?
Old May 20, 2012 | 12:43 PM
  #330
BAD954BOI's Avatar
BAD954BOI
Looks mean sides ways loo
