Noob here with probable noob question.
Old Dec 16, 2009 | 04:53 AM
ghettoSi's Avatar
ghettoSi
Post Noob here with probable noob question.
Alright guys take it easy on me, I have what are probably some very basic questions. I have searched, but the results have only left me more confused. I am looking at picking up an early model SC300 with preferably a manual transmission. This is where my questions begin. Although I am aware that the stock motors can handle quite a bit of power (I have a friend who's car makes around 500whp), I am interested in swapping the 2jzgte into mine.
I am not interested in making a huge number really, I would just like the all around reliability that would come with the factory twin turbo set up. I would like to know what all would be needed to complete this swap. I have been looking at purchasing a complete motor with harness, ecu, tubos, etc. off either ebay or from another supplier.
My second set of questions then has to do with the transmission. The swaps I have been looking at have all been automatic swaps out of Aristos. Although I am aware of the advantages of the R154, and especially the 6 speed transmissions, would the W58 bolt up with any major issues to the 2jzgte? Would it have any problems putting up with the power from a relatively stock gte swap?
Sorry for the long read guys but I'm hoping that this is a place I can get some answers. Thanks in advance!
Old Dec 16, 2009 | 08:40 AM
Shadowen's Avatar
Shadowen
I've been on the same journey. Here's what I've picked up.
Your questions:
What all would be needed to complete this swap?
As far as I know, you will need the engine(with turobo's) a downpipe for the Gte, Wiring harness (Spliced by Dr Tweak, or DIY) and the ECU. Also, you will need the piping and intercooler.
Would the W58 bolt up with any major issues to the 2jzgte?
Yes, though you will need an adapter plate, but it wont be too complicated i cant imagine.
It will easily hold the power of the stock twins. The transmission is pretty solid and unless you're going to be racing it, It will work just fine for you.
And please correct me If I'm wrong, This is just my understanding.
Old Dec 16, 2009 | 09:14 AM
TLDriver's Avatar
TLDriver
The W58 will bolt up to it. You will need the 2jz/w58 flywheel no need for an adapter plate. If you start with a 5 SC you will have all the parts for the trans to bolt up to the gte.
Can it handle the stock power of a gte?
Sure can... but make sure to get it looked at the condition of it before putting it in. If you abuse it clearly it will give after some time, even if you don't abuse it eventually all transmissions will give.
Old Dec 16, 2009 | 03:10 PM
TURBO819's Avatar
TURBO819
Default Two Threads For You
https://www.clublexus.com/forums/per...to-2jzgte.html
https://www.clublexus.com/forums/per...t-gt3582r.html
The W58 is said to be good for about 450rwhp. I also depends on your driving style.
Old Dec 16, 2009 | 03:52 PM
ghettoSi's Avatar
ghettoSi
Awesome, I knew I would be able to get some answers here. So about how much does Dr. Tweak charge to splice a harness? I'm really not much for wiring although I could probably get it done myself.
Old Dec 16, 2009 | 10:09 PM
Shadowen's Avatar
Shadowen
https://www.clublexus.com/forums/1ge...-for-sale.html
Old Dec 16, 2009 | 10:46 PM
ghettoSi's Avatar
ghettoSi
Thanks for the links guys. So would that harness and ECU be plug and play with the new motor? Its all gonna come down to finding a fairly cheap 5 speed SC300 once I sell my civic.
Old Dec 16, 2009 | 11:24 PM
mikeydelro's Avatar
mikeydelro
Sounds like a good plan but the 5spd SC3's are hard to find. Especially a cheap one.
Old Dec 17, 2009 | 04:23 AM
ghettoSi's Avatar
ghettoSi
I know, how hard are the auto to 5 speed conversions?
Old Dec 17, 2009 | 08:25 AM
lemmiewink's Avatar
lemmiewink
It is quite... involved but straight forward. You will have to do cutting on at least for the clutch master cylinder and for the shifter position.
I would suggest doing the conversion with your engine swap, and mounting as much as you can with the engine out of the engine bay.
Old Dec 17, 2009 | 09:30 AM
TLDriver's Avatar
TLDriver
Just a suggestion... Get an SCX00 auto, get a 1jz with a 5 speed on it pref not for an mk3 and slap that in. You will end up with a 2.5L Twin Turbo R154 5speed ready for some abuse and you would only have to extend the harness a few inches. Your cost would be much less and your options would be still there for upgrades.
KahnBB6
Jul 11, 2013 08:02 AM
gnukk123
Sep 9, 2009 10:15 PM
$hogunn
Nov 5, 2007 07:33 AM
sc300gte
Feb 1, 2007 10:16 AM
