BIG suspension problems
Old Nov 20, 2009 | 07:12 PM
Cwall's Avatar
Cwall
Default BIG suspension problems
My SC has become an absolute mess suspension wise. I feel EVERY bump in the road and the SC usually pulls left/right over large bumps. I had an alignment done about 2 weeks ago to "fix" this problem and it was considerably better for a couple of days, but has now gone back to terrible. My girlfriend won't even drive my dream car anymore! I'm thinking bushings (all around) are the culpret, but would there be this much suspension problem? Thanks in advance for any insight.
Old Nov 20, 2009 | 08:31 PM
dwebb99's Avatar
dwebb99
Broken/torn Front LOWER control arm bushings are a Very common problem on these cars(start expecting these to go bad at 100,000 miles or so). Most everyone just changes these out with Supra Front Lower control arms (cheaper price). What's the mileage on your car? Front Ball joints, tie rods, wheel bearings,steering rack bushings.suspension mounting bolts loose, any one of these things (could be more than just one thing as well) could be the culprit. ALL of these things are very easy to check to see if the are defective/worn. Just do a search. ALSO, check for bad tire problems, and bent wheels, wheel balance etc., search and check and ye shall find....
Old Nov 21, 2009 | 12:15 PM
TankMR's Avatar
TankMR
Like other dude said it could be a variety of problems. I was in the same position, blown shocks and worn lcas. I installed coils and LCAs and STILL have that same bullcrap where the steering wheel jerks all over. Time to do rack bushings now...anyways good luck.
Old Nov 21, 2009 | 02:02 PM
TheMole's Avatar
TheMole
If not anything mentioned above, check the inner/outer tie rod ends.
Old Nov 21, 2009 | 02:24 PM
CrazySC300's Avatar
CrazySC300
Ugh! Who knew that SC suspension would be such a nightmare? I have issues with my suspension as well...That's why I'm just saving my money to have a suspension set up where everything is fully adjustable, From coilovers to LCA's you name it.
Old Nov 21, 2009 | 04:44 PM
Cwall's Avatar
Cwall
My SC has 174,000 miles. I will get under the car tomorrow and hopefully find the problems. I did notice earlier that my steering rack boot is torn open on the driver's side.
Old Nov 24, 2009 | 07:08 AM
5sp_jzz30's Avatar
5sp_jzz30
whatever happened to using search to answer your concerns?
Old Nov 26, 2009 | 03:53 PM
scfou's Avatar
scfou
Sorry to hear about your situation. I totally feel your frustration. I use to drive a 92sc3 which drove very nice at the beginning, but eventually drove like sht also. What I started first was replace the steering rack bushings with urethane ones, both sides, and it actually drove worse, Lol.. I have no idea why but eventually I replaced them with factory Lexus ones, and it took away the steering play almost immediately. Then I replaced both upper control arms following, gave it an allighment, and all the problems went away. It actually drove like a brand new car. Hope that helps.
pbxcomm
Suspension
Dec 5, 2018 04:02 AM
Dtaylor3
Dec 29, 2014 04:13 PM
Ali y0
Suspension and Brakes
Mar 9, 2011 09:59 PM
hondaatwsu
Jan 8, 2011 09:45 AM
