Lowering Springs? Alignment?
Old Nov 12, 2009 | 07:08 PM
93sprucesc's Avatar
93sprucesc
Default Lowering Springs? Alignment?
hello everyone,
I lowered my sc300 not more than 2 months ago and at the same day, had it aligned. Now, i lowered my car with espelir springs and two months later my brand new falken tires are completely worn out. However, it is not the inside camber, the outside is worn out. So i took it back to complain about the alignment and expecting for them to give me two new free tires (the rears are fine). They explained to me that my car got even lowered through the time and messed up the alignment again. The first time i brought my car it was able to go onto the rack but the second time they had a hard time. So my question is, guessing that the car settles in more and lowers, does that messed up the alignment? Please let me know.
Old Nov 12, 2009 | 07:11 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Yes, as the car lowers itself more and the springs settle, the alignment will be off no matter what. I would have waited to get the alignment unless it was bad and REALLY off when you first lowered it. You should give the springs a couple more weeks to COMPLETELY settle and then get an alignment for the last time.
BTW, what springs did you use? Also, did you just put lowering springs on stock struts?
Old Nov 16, 2009 | 12:35 AM
wexpac's Avatar
wexpac
Was wondering the same exact question because I almost bought some springs for my stock struts the other day... good, bad, or horrible idea?
Old Nov 16, 2009 | 09:09 AM
kez's Avatar
kez
bad bad idea the stock struts wont hold up with the stress from the lowering springs
Old Nov 23, 2009 | 12:56 PM
TrackMonky's Avatar
TrackMonky
Originally Posted by 93sprucesc
hello everyone,
i have a question for the espelir spring on ur car...i was wondering hows the ride quality....is it soft? Stiffer? or close to stock comfort???
Old Nov 23, 2009 | 04:58 PM
edwinbong's Avatar
edwinbong
should let suspension settle before getting alignment.. or see if the place has some type of warranty
Old Nov 23, 2009 | 06:35 PM
nfordhk's Avatar
nfordhk
Espelir are suppose to ride just like stock well until you go over a bump haha. And my brother is lowered on springs stock shocks over a year now no problems. I think eventually its a good idea to get upgraded shocks but right away? Not needed.
Old Nov 24, 2009 | 12:14 AM
TrackMonky's Avatar
TrackMonky
sorrie to ask but the tanabe springs dont have as a aggressive drop from what i hear,,,,please correct me if im wrong!!!
swoo350
IS F (2008-2014)
Aug 20, 2015 08:04 AM
Napalvr
May 18, 2015 08:00 AM
blooch253
Suspension and Brakes
May 2, 2014 08:29 AM
delos
Mar 21, 2010 04:44 PM
sway162
Wheels, Tires & Brakes Forum
Jul 16, 2009 03:27 PM
