Wheel Alignment
Old Jul 14, 2009 | 09:14 AM
sway162's Avatar
sway162
Default Wheel Alignment
I just swapped out my OEM springs for the Eibach Prokit. This was done last Thursday. So far I have drove probably around 260 miles on the Eibach springs.
I have found inconsistent answers on when it's the best time to get an alignment done. Some say to get it done right away and others from a week to 4 weeks after install. Would I be okay to get an alignment done by this Thursday? I think I have put enough miles on the springs for them to "settle" in. I would appreciate any advice. Thanks!
Old Jul 14, 2009 | 10:15 AM
rominl's Avatar
rominl
exclusive matchup
imho 1-2 weeks of normal driving is more than enough
Old Jul 14, 2009 | 10:35 AM
sway162's Avatar
sway162
Thanks rominl! I appreciate the response.
Old Jul 14, 2009 | 12:24 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
If possible, immediately, and then again a few weeks down the road... when the car was lowered, camber, caster and probably toe have all changed well beyond acceptable limits and can cause bad tire wear quite quickly...
If you only want to do it once, a week is more than enough...
Old Jul 16, 2009 | 02:51 PM
sway162's Avatar
sway162
Thanks! Hopefully you can help me out on this. I just got an alignment done today by a Toyota dealership near my work.
The specs look odd to me, or doesn't seem right. I don't know much about this except from just searching and reading what other poeople have talked about their alignment specs. Here are my specs, and this only on the Eibach Prokit springs on stock shocks:
Front
Left
Caster 5 46'
Camber -0 34'
Toe 0 05'
Right
Caster 7 27'
Camber -0 43'
Toe 0 04'
Rear
Left
Camber -2 00'
Toe 0 09'
Right
Camber -1 43'
Toe 0 08'
Thrust Angle 0 01'
Doesn't the camber measurements seems to be a bit off in the rear? I would appreciate any help anyone can provide on this. Thanks!
Old Jul 16, 2009 | 03:27 PM
mitsuguy's Avatar
mitsuguy
I'm surprised it doesn't pull... caster on the front is a big variance...
also, rear camber is out of whack a little, but may be all they can do, being its lowered...
Napalvr
May 18, 2015 08:00 AM
blooch253
Suspension and Brakes
May 2, 2014 08:29 AM
monkeybutt
Apr 23, 2011 02:14 AM
delos
Mar 21, 2010 04:44 PM
93sprucesc
Nov 24, 2009 12:14 AM
