1. My key wont come out. The only way it will come out is if the battery is pulled.
Can anyone help?
2. 1JZ Swap wont start 92 SC300 Auto. :happysad:
Its cranks but will not turn over.
Fresh Fluids
Fresh Plugs
Checked...
Body/Electrical Plugs
Alt.
FuseBox
Starter
Ignitor
Gas in the car...:ugh2
Although the car has had no gas since the last motor was pulled. I put in maybe 2.5 gal.)
12v Mod
Can anyone help?
Fresh Fluids
Fresh Plugs
Checked...
Alt.
FuseBox
Starter
Ignitor
Although the car has had no gas since the last motor was pulled. I put in maybe 2.5 gal.)12v Mod
Maybe your tranny is not in the park position. Thats the only thing that comes to my mind when the key doesnt come out.
Did you just finish the swap?
What do you mean "Its cranks but will not turn over."
If you turn the key to start and hear nothing, it's not cranking nor turning.
You may not have the Neutral safty wire hooked up. The wire affect in P and N.
Check IJ2 pin 10 (black/white wire) and hook directly to body ground and turn key again to start. If it starts, be caution because it will start in any gear.
If it starts now and you want to be safe. Re-wire time. Check P1 (from tranny) connectors.
P1 pin 2 (Black wire) to EB1 pin 3.
P1 pin 3 (Black/White wire) to IJ1 pin 6.
If it doesn't start with grounded IJ2 pin 10. Check your starter wire that lead back to connector EB2 pin 1 (Big Black wire)
Quote:
Can anyone help?
Fresh Fluids
Fresh Plugs
Checked...
Alt.
FuseBox
Starter
Ignitor
12v Mod
Originally Posted by SC2JZ300
1. My key wont come out. The only way it will come out is if the battery is pulled.Can anyone help?
Fresh Fluids
Fresh Plugs
Checked...
Alt.
FuseBox
Starter
Ignitor
Quote:
Will be checking. Originally Posted by t70 supra
what about the tranny override? did u check that next to the shifter
and vangb2.... Its an auto.
It cranks... as in when I turn the key it just keeps cranking. Then it does not turn over....
do you have an alarm system with an auto start? my sc300 had an issue one time, it cranks but does noet turn over, turned out my alarm was acting up... i took out the fuse for the alarm system and it started with no problems... since then i never used my auto start feature...
Quote:
I dont have a 5 Speed. Why would I need to do that.Originally Posted by vangb2
have you check the following above on the pinout?
Quote:
Timing is dead on. Originally Posted by codye3m
it might be the timming
And no I dont have an alarm system.
