?Question?
Old Oct 14, 2009 | 09:55 PM
rel0610's Avatar
rel0610
5th Gear
Default ?Question?
Just bought this 95 SC400 and the TRAC ABS lights are on any ideas?
Old Oct 15, 2009 | 02:50 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Stop by AutoZone or Advanced and see what sensors its tripping. They may be able to get you in the ballbark. Sounds like possible TPS sensor. JMO
Old Oct 15, 2009 | 02:55 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
don't go to autozone, you have an odb1 car, and pulling the trac codes is different than pulling the ecu codes.
you jump 2 terminals in the diagnostic port. do a search for it. it will blink in a pattern, then you look up the number. could be low on brake fluid, secondary tps needs adjusting, there are like 100 posibilites so you will need to report back with the actual code.
at least the code will narrow it down to a few usual suspects.
Old Oct 15, 2009 | 04:32 PM
ashtray's Avatar
ashtray
id rename this thread lol.
Old Oct 15, 2009 | 08:22 PM
Vortes's Avatar
Vortes
all you need to do is get a paper clip, bend it, and have a fun time attempting to keep the clip against the 2 terminals and watch the flashes lol, should be a guide on the site somewhere, not exactly sure what terminals.
Old Oct 15, 2009 | 08:41 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Kinda one of those things you might wanna know before you buy it? (seeing as the trac and ABS lights lit up point to a code that refers to a bad torque converter most of the time and can cost as much to replace as half what you paid for the car if you have no real shops around that know their way through an SC).
This is one error code I'd checked before signing the papers. TQ's on stock cars + repair shops = broke, broken, wallet gone.
Old Oct 16, 2009 | 03:55 AM
pmpdaddyt's Avatar
pmpdaddyt
my sensor broke off, so check to make sure the sensors are still there and are connected
ScDre
Oct 30, 2012 02:33 AM
CallmeQ
GS - 1st Gen (1993-1997)
Sep 26, 2009 12:19 PM
soarer13oy
Aug 29, 2009 04:57 PM
pitmanr200
Aug 9, 2008 09:27 PM
