Questions
Old Apr 23, 2002 | 09:00 PM
Nico's Avatar
Nico
Default Questions
Is this type of model for light bulbs exist :
9006/HB4J ?
I went to a shop and ask for the specific headlight 9006/HB4 socket.. they took my light bulb and looked at it then the guy said i need 9006/HB4J model t..... is this right? he says the car is from japan.
Went to 2 website online trying to find out more things about the 9006/HB4J but couldnt found any thing at all..
I tought 1991 TOYOTA SOARER V8 takes those 9006/HB4 (normal one's not the HB4J...
there's some lights that says 60/55 watt = 90/80 watt is that fine to use in the soarer? will it melt anything.... does that mean that it will consume 55 watt but the output will be 80 watt, so the temperature is of a 55 watt and bright as 80 right???
Last question..
will supra air filter fit in the V8 soarer ? does it add any performance at all without changing the exhaust?
any input will be appreciated.. thanks
Old Apr 23, 2002 | 09:06 PM
Nico's Avatar
Nico
Default UPDATE
Just updating:
One of the guy in the shop also said that i could probably fit a 9005 in the 9006 socket.. just have to cut something in the 9005 to make it fit..
which is bigger in diameter :
9004 or 9007 ?
also
I need find a right hand blinkers (signal) (yellow) on the front bumper bar for a soarer does anyone here know where i can get it from cause mine is totaly cracked cause some bastard couldnt park his car properly and to make things worse.. he didnt even leave a note to tell me who he is. (online store preferred cause i'm gonna order this from sydney - australia)
thanks again.
ScDoinIt
Sep 11, 2011 03:25 PM
jlo0109
May 10, 2007 01:04 PM
BLK13X
Lighting
Sep 3, 2003 11:07 AM
NAZTY97
Sep 11, 2002 03:07 PM
