Subwoofer replacement
Old Apr 21, 2002 | 01:45 PM
rockman-vgw's Avatar
rockman-vgw
Question Subwoofer replacement
I have a 92 SC 400 with the Nakamachi audio system. I want to replace the 10" sub. I have removed the 4 bolts that I believe are holding it in, but I still cannot get the sub to budge. I want to replace it with a 10" Pioneer TS-W254F free air sub. Any ideas how to remove the old sub?
Old Apr 21, 2002 | 02:07 PM
c_irie's Avatar
c_irie
did you remove the rear dash ?
Old Apr 21, 2002 | 05:12 PM
SupraCoup3's Avatar
SupraCoup3
https://www.clublexus.com/forums/sho...hlight=removal
my e-how to remove the rear seat, so you can get to the sucker. (This is my SC w/ the premium, non- NAK system... but rear seat is the same)
John...
search & ye shall find.
EDIT: also be carful that your new sub doesn't go bouncy bounce off your fastank... err gas tank.
Old Apr 22, 2002 | 09:54 PM
rockman-vgw
I removed the rear dash and have the 4 bolts out of the speaker, but it's still in there tight. Might need to get out the dremmel roto tool.....
Old Apr 22, 2002 | 11:20 PM
c_irie's Avatar
c_irie
you should not have to use a dremel ...try prying up the sub-woofer support along the edge until it breaks loose
IS250Slvr
Aug 20, 2020 06:04 PM
AZ IS350
Apr 10, 2015 09:53 AM
fluxx
Apr 26, 2008 02:54 PM
YupImJOee
GS - 1st Gen (1993-1997)
Oct 12, 2007 09:05 AM
southernsc
Jan 10, 2004 03:09 PM
