removing rear sub
Old Apr 26, 2008 | 10:21 AM
fluxx's Avatar
fluxx
Default removing rear sub
does anyone know how to get to the oem sub to remove it? any diagrams anywhere? i searched but no luck.
Old Apr 26, 2008 | 10:27 AM
WhatYaGot's Avatar
WhatYaGot
I am installing a sub and sub amp myself tomorrow and leaving the stock sub in, but disconnected. Just curious to know why you want to remove it?
Old Apr 26, 2008 | 10:38 AM
Brian231's Avatar
Brian231
Usually, you should remove the rear seat bottom and top and then the rear deck lid. The sub bolts down from the top under the panel. Their are two bolts that hold the seat bottom on. You have to remove the bottom part first and then you will see the bolts for the top portion. You should be able to do this with little effort.
Old Apr 26, 2008 | 10:45 AM
fluxx's Avatar
fluxx
basically i want to do what some of the gs guys have been doing.
https://www.clublexus.com/forums/sho...d.php?t=294209
https://www.clublexus.com/forums/sho...d.php?t=350996
i have a sub in there now, but i just want some trunk space back.
thanks brian. i tried to tug on the bottom seat a little, but i guess why thats why it didnt budge. haha ok i think i can figure it out from there.
Old Apr 26, 2008 | 10:49 AM
Brian231's Avatar
Brian231
Yes, it can be snug from the factory install. The two bottoms bolts may be hidden from the seat cushion folding over it a bit. Run your finger under the seat cushion between the floor carpet to identify the hold down bolts. You will probably have the both seat assembly's and the rear deck-lid out in half hour taking your time. I forgot to mention, you may have to remove the piller pieces and be careful to not pinch the curtain airbag coil when you re-assemble.
Old Apr 26, 2008 | 02:54 PM
jns350's Avatar
jns350
Default rear subwoofer diy
I just did my IS last night!!! I added a aftermarket sub and amp to stock non-ML system.... you need to remove to rear sub for more sound pass-through here is the link I used.
https://www.clublexus.com/forums/sho...50#post3191050
If it was not for this link then I would have finnished today not last night
IS250Slvr
Aug 20, 2020 06:04 PM
jbrittmart
Jul 1, 2011 10:29 AM
kaldES98
Apr 23, 2009 04:38 PM
FinLIFE
Sep 23, 2008 07:11 AM
southernsc
Jan 10, 2004 03:09 PM
