Adjusting the SC door
Old Apr 19, 2002 | 06:41 PM
VQT's Avatar
VQT
Default Adjusting the SC door
Does anyone knows how to adjust the SC400 door?
I need to move the door back a few mm. The driver door front edge is touching the edge of the fender . Just found it today after the paint has been chip off from the edge of the fender.
I don't know how the door move without anything happen to it
The manual read to adjust the door vertically or back and fort, loosen the body bolts. Hint: take the pin out to adjust. I can't take the pin out
Old Apr 19, 2002 | 08:50 PM
krypto's Avatar
krypto
Sorry I can't be of any real help...I'm pretty damn sure I have the same problem. Gotta check....They are some pretty heavy *** doors...But, then again... I've been out drinkin so, who the f*&^ knows? And what the f do I know?
Not sure if anybody esle has this? Mine is very slight. Meaning not too bad on where it rubs....Slight cheap(lol)chip/spot.....
I'm pretty damn sure my cars never been in an accident..Carfax, drives tight as a drum, etc...Been serviced/on lift at Dealer...So..
Anybody else heard of this?..Recall? While Im at it and drunk...WHats up with recalls? Can we take our cars and they fix some special things for free, if not already previously preformed?..
Old Apr 19, 2002 | 09:00 PM
RacerDex's Avatar
RacerDex
I know on my 95 SC300 (actual production date of Feb 94) they did have a recall on the door hinges and/or the bolts holding them on.
I had gone in for service once, and my service writer was checking out the car, and specifically looked to see if that was done. The give-away is that the bolts will be chrome/nickel-colored, vs. being painted over the color of the car.
Though I believe they did change these hinges for the 95+ coupes, you may still be able to get info on how this may apply to any earlier model.
Old Apr 20, 2002 | 12:21 PM
itzloud's Avatar
itzloud
Damn this is weird...My door has just started to do this same thing. Now I have a slight chip where the door was rubbing.
Old Apr 20, 2002 | 04:21 PM
VQT's Avatar
VQT
So, Lexus SC has flaws just like other cars
Old Apr 21, 2002 | 09:31 AM
krypto's Avatar
krypto
Question
what is flauses?
Old Apr 21, 2002 | 10:47 AM
VQT's Avatar
VQT
Originally posted by krypto
what is flauses?
Flaws Sorry
Old Apr 22, 2002 | 06:58 AM
VQT's Avatar
VQT
I guess only three people belong to this forum have problems with the door rubbing the fender:eek: , and no one here ever have to adjust the SC door.
Old Apr 22, 2002 | 09:42 AM
RacerDex's Avatar
RacerDex
It must be one of those ancient Japenese engineering secrets.
It looks like there is just a stronger bracket w/ stronger bolts that was replaced on my 95. That "upgrade" may also work for the earlier models. My service writer said it was needed for the heavy doors, so my thought is that the better "fix" is to replace the brackets vs. adjusting the door (since there are no replies to that affect to help you).
Old Apr 22, 2002 | 10:08 AM
VQT's Avatar
VQT
I guess you mean the door hinge because I don't see any bracket that is attach to the hinge. It must be a whole unit change out.
Last quote I got was ~$200 each
Old Apr 22, 2002 | 05:26 PM
vaki2's Avatar
vaki2
Unhappy
well, add me to the list, I have the same problem on the driver side. Was wondering how to actually fix it. If someone has any experience changing the hindge, please post how they did.
thanks
Old Apr 22, 2002 | 05:47 PM
VQT's Avatar
VQT
thanks
www.lexusclub.co.uk
look for Fixes & Repairs, subject door hinge
Bretth
Mar 9, 2017 01:43 PM
Tymboo
Feb 23, 2016 01:21 PM
rykwebb
May 28, 2008 07:27 PM
97SC
Dec 19, 2003 02:24 PM
jdmsoarer
Feb 25, 2003 02:19 PM
