Power Steering Boost
Old Aug 16, 2009 | 11:43 AM
guod's Avatar
guod
Default Power Steering Boost
I was wondering if there was any way to reduce the boost on the power steering. I want to have the steering feel a little heavier with increased road feel. I already replaced the steering rack bushings but still would like to have less boost on the power steering.
Old Aug 16, 2009 | 01:19 PM
QwkSC's Avatar
QwkSC
Go get an alignment. Tell them you want the most caster possible.
Old Aug 16, 2009 | 01:45 PM
guod's Avatar
guod
would more caster give heavier steering? wouldnt that give uneven or strange tire wear since the tires are at a strange angle?
Old Aug 16, 2009 | 02:47 PM
rykwebb's Avatar
rykwebb
Just get rid of it, if you want to feel the road. It's good for the shoulder muscles as well.
Old Aug 16, 2009 | 06:04 PM
guod's Avatar
guod
i would still like power steering, just with heavier feel. i thought just having less boost would do it. is there a simple way to adjust boost?
Old Aug 16, 2009 | 06:06 PM
Luxor's Avatar
Luxor
unplug the speed-sensing sensor on the power steering rack.
Old Aug 16, 2009 | 06:14 PM
guod's Avatar
guod
what does that do?
Old Aug 16, 2009 | 07:36 PM
Luxor's Avatar
Luxor
it activates the progressive power steering, it will not assist in steering at low speeds.
Old Aug 16, 2009 | 07:39 PM
guod's Avatar
guod
but it still means i will have very light steering at high speeds? or will it just be a bit heavier overall? what are low speeds?
Old Aug 16, 2009 | 07:55 PM
guod's Avatar
guod
also, do you have a pic of the connector? what side of the rack is the car on?
Old Aug 16, 2009 | 08:02 PM
itazura's Avatar
itazura
get the SS power steering line from LuxuryMods. it will take the power assist off and creates quicker response.
Old Aug 16, 2009 | 08:11 PM
UpInTheLex's Avatar
UpInTheLex
He has SC400. Will that power steering line still work?
I would just suggest unplugging the connector from the rack and pinion unit.
It's a two wire connector and the only one attach to the rack. It will firm up low speed for sure. 40mph and less.
Old Aug 16, 2009 | 09:04 PM
guod's Avatar
guod
does anyone have pics of the connector or is it obvious? I replaced the steering rack bushings and put new sway bars in on Saturday but didnt pay attention to a connector.
Old Aug 16, 2009 | 09:47 PM
QwkSC's Avatar
QwkSC
Your thinking of Camber,
-Toe is the tire pointed in or out looking from the top
-Camber is the tire leaning in or out from the front
-Caster is the distance from the center of the tire to the point that the tire rotates upon. Think of it as moving the tire further towards the back of the car.
Increasing caster will increase the effort required to turn the wheel, And also make the wheel snap back to center faster. There is no tire wear associated with increasing caster, just steering effort. So i like to run as much as possible, especially if you are going to drift because you can get that opposite lock going faster
Old Aug 16, 2009 | 09:48 PM
QwkSC's Avatar
QwkSC
BTW, does anyone know if the Supra rack swaps in? I believe it has a faster ratio.
