Need help, dont know whats wrong...
Old Aug 3, 2009 | 03:12 AM
cardwielde's Avatar
cardwielde
Default Need help, dont know whats wrong...
i have a 92 na-t and it was running 8.5psi and i was at the track made a couple of passes and then i pulled the vacuum on the wastegate and ran more boost. it went up to 12psi and during that pass white smoke was pouring out like crazy and the breather on the valve cover was blowing out oil. the temp was in the middle and i wasn't low on oil or any other fluids before the pass. my O2 gauge wasn't leaning out during the pass it was still reading rich and it is now miss firing. i don't know what is wrong with it. i'm guessing it could be a fried ring, melted piston, stuck valve or the most common 2J problem the BLOWN HEAD GASKET... if anybody can give me some insight as to what has happened or whats going on please let me know.
Old Aug 3, 2009 | 07:53 AM
turbodremz's Avatar
turbodremz
sounds like a HG..does your oil look milky?
Old Aug 3, 2009 | 11:07 AM
cardwielde's Avatar
cardwielde
no it doesnt. it looks normal.
Old Aug 3, 2009 | 04:25 PM
StiCk3's Avatar
StiCk3
it sounds like something internal busted up. Probably a piston or two. Do a leakdown test to check for compression leaks, that would be my first place to start.
Old Aug 3, 2009 | 05:14 PM
meangreen1's Avatar
meangreen1
Sounds just like my STi. Blown HG
Old Aug 3, 2009 | 06:00 PM
megamarine's Avatar
megamarine
I had this happen to one of my close friends. We discovered it was a blown HG. You probably have the same thing.
Old Aug 3, 2009 | 09:29 PM
Carfreak70's Avatar
Carfreak70
Im gonna vote BHG....ive heard of this happening to a few 2jz's
Old Aug 3, 2009 | 11:36 PM
topdog849's Avatar
topdog849
white smoke means coolant burning. drain your oil if it looks like chocolate milk its your hg. or if theres oil in your coolant.
megamax
Aug 26, 2018 12:41 PM
sj408
Aug 20, 2012 10:19 AM
al0389
Feb 28, 2012 05:24 PM
THUGRIDAH
GS - 1st Gen (1993-1997)
14
May 4, 2004 09:37 AM
MarkE
Dec 30, 2002 11:56 PM
