Fuel Pump DIZASTER/DEVIL PROBLEM
Old Jul 27, 2009 | 10:30 PM
Mortal300's Avatar
Mortal300
Exclamation Fuel Pump DIZASTER/DEVIL PROBLEM
I am going crazy.
Today i decided to install my brand new Walbro Fuel Pump.
I pulled out the old fuel pump....disconnected it...then connected the Walbro IN THE PROPER WAY.
Connected back the battery and then turned the ignition on....READY FOR THE MAGIC???? THE WALBRO DID NOT TURN ON!
1. Fuses are fine.
2. ECU is fine
3. Nothing is unplugged.
4. To my knowledge nothing is shorted (atleast we hope)
5. YES THE WALBRO WORKS ( Connected to battery to test to see if i had a bad pump and it worked*)
Now the devil effect takes place.
I figured HEY LETS TRY THE OEM FUEL PUMP TO SEE IF THAT WORKS.
Guess what....now the OEM fuel pump wont even work when connected to the wires.
Im lost...i dont know what to do anymore....im thinking of just wiring to the battery and using a relay bypassing the ECU but i DONT want to do that because i wanna know why the hell my basic setup is not working RANDOMLY on the car....
Any help people?
Old Jul 28, 2009 | 12:01 AM
Mortal300's Avatar
Mortal300
Well now that im reading more....is it possible that my FP ECU is not letting the pump to start at all?
I havent tried starting the car but when the key is in ignition and turned on ACC...the pump should turn on.
Now the stock pump wont even turn on.
Did i fry the ECU cus the fuses look fine both under the left foot and under the hood.
Im confused!!
Do i do the 12v FP ECU mod? I mean the pump wont even start. Not even the STOCK ONE PEOPLE!
Old Jul 28, 2009 | 12:17 AM
sc-driver's Avatar
sc-driver
i dont know if this will help at all but try disconnecting and then reconnecting your battery with the stock fuel pump connected. Man that really sucks though
Old Jul 28, 2009 | 12:24 AM
turbodremz's Avatar
turbodremz
My walbro pump does the same thing..try and start the car and you will hear it prime and it should start right up. I thought something was wrong too, then I actually started the car, and it fired and fuel pressure was excellent once the key was turned all the way..just crank it over
Old Jul 28, 2009 | 12:27 AM
vinh's Avatar
vinh
Do the Fuel Pump ECU mod and see how that works. After i installed my Walboro, my ECU fried the next day. I bypassed it and i was good to go.
Old Jul 28, 2009 | 11:27 AM
Mortal300's Avatar
Mortal300
Really? But when i disconnected the walbro and then hooked up the stock one and turned the car in ACC (did not turn on car) the stock one didnt even turn on.....
Will the excess fuel recirculate since the 12v mod is constantly pushing fuel in?
iM gunna try that MOD today and see if it primes before actually starting the car.
Old Jul 28, 2009 | 12:57 PM
turbodremz's Avatar
turbodremz
that I cant try, I already trashed the stock pump otherwise I would hook it up and see what happens. and yes the excess fuel will be recirculated. just do the 12v mod and be done with it, plus it will save you the headache later on..my interior is still in pieces cause I still need to do the 12v mod myself..let us know how it turns out.
Old Jul 28, 2009 | 12:59 PM
codetoad's Avatar
codetoad
Yes, the excess fuel will rush into the return line, you will hear it, trust me
I think Walbro's cause our FP ecu's to crap out. 12v mod is a must anyway. Hell, i had to wire switches in to power my ECU's main relay because i guess it's faulty now, because my FP would stay on with the engine off. Hoping it's just my ECU and when I swap that problem goes away. I'd like to be able to use my turbo timer without having to flip a switch.
Old Jul 28, 2009 | 03:05 PM
Mortal300's Avatar
Mortal300
Yeah damn thats a headache codetoad.....
12v MOD e.t.a 2 hrs.
gotto go to autozone get vacuum lines for the BOV and caps for the EGR mod i did!
Old Jul 28, 2009 | 03:07 PM
Mortal300's Avatar
Mortal300
i apologize mods for the incorrect forum placement
( i was too pissed off that a simple walbro install went into a 2 hour headache of WTF happened to the damn car)
Old Jul 28, 2009 | 03:08 PM
Gspec's Avatar
Gspec
Fuel pump relay....
Old Jul 28, 2009 | 03:12 PM
Mortal300's Avatar
Mortal300
Originally Posted by Gspec
Fuel pump relay....
i wanna figure out why the pump just wont start before i do that...
yes theres almost a solution to everything but if i go ever stock again i want the car to work without havin the relay and straight 12v
Old Jul 28, 2009 | 03:13 PM
Gspec's Avatar
Gspec
I'm talking about the OEM relay....is it working?
Old Jul 28, 2009 | 03:23 PM
Mortal300's Avatar
Mortal300
the one under the hood of the car where the fuses r?
Old Jul 28, 2009 | 07:22 PM
Mortal300's Avatar
Mortal300
PROBLEM SOLVED!!!!!!!!
12V MOD WORKED!!!!!!!!!!!!
Damn walbro is pretty loud for a ****ty *** fuel pump....there must be some sick *** loud ones out there.
