Power
Old Apr 2, 2002 | 04:30 PM
Toog4me's Avatar
Toog4me
Default Power
Ok... i know i have posted a thread simialar to this, but i never really got a clear answer. My 2k SC4 has the 300hp vvti engine ... i want to bump power upto 350 or more if possible for not too much dough (not more than 9k)
The only thing i have added for performance is the weapon ecu and high performance exhausts and intake... and a torque converter
im trying to remember what else i have on the car.. but lets just say the car is pretty much stock...
how much, where can i go, what exactly do i need?
thanks...
i want to know because i got creamed by a yukon with my girl in the car and it was embarrasing.. the guy had me the entire time...
Old Apr 2, 2002 | 04:38 PM
Lex Luthor's Avatar
Lex Luthor
With N2O or without?
Old Apr 2, 2002 | 05:50 PM
lex400sc's Avatar
lex400sc
A baby tap of NOS should get you there, but if you're gonna juice your car, 150-shot direct port injection alll the way!!!
Are you aiming for 350 at the crank or at the wheels? Cause you probably have close to 350 at the crank with the ECU, TC, and intake. That aftermarket exhaust my be hurting your torque numbers though. Those V-8 Yukons are torquey SOBs. You would have pulled on him quickly had you kept it up. I hung with my friend's V-6 S-10 in my stock '95 SC400 with passenger weight about even in both cars.
Old Apr 3, 2002 | 09:47 AM
mor-power's Avatar
mor-power
I creamed my friend's Yukon the other day, too... But not with my SC3 since it is still waiting for the Toyomoto Kit to be installed. I had to use my ML55.
Old Apr 3, 2002 | 02:40 PM
Toog4me's Avatar
Toog4me
well, im comfused about no2... is it like in f and f where you have to push a button or does it always run through your car? The yukon pulled me right away it wasnt me... i was at sepulveda and wilshire at the red light... i looked at the guy and started laughing pretending to race him cuz i didnt think he could beat me... lights green, i did my thing, he did his thing, and pulled me so badly!!!!!! i got to 60 in less than 6.3 seconds but how the helll did he??????
thanks! i got a GReddy exhaust... how can it be bad for the t numbers? and im looking for that power at the wheels!!!
thanks
Old Apr 3, 2002 | 02:49 PM
Anthracite SC's Avatar
Anthracite SC
Default Welll
I don't think it was how SLOW your Sc4 was..but he must've had something special under the hood of that yukon.
First off, your set up is NOT slow. w/torque conveter, you should be doing WELL under 6 seconds w/the 300hp vvti. w/the vvti alone is low sixes.....
Add the torque converter and weapon-r ecu/intake and u should easily be doing mid5s.....
That's the EXACT setup I'm planning after my engine swap.
I'll ahve the 300hpvvti like you, I have the high stall speed torque converter..and then I'll shop around for the ecu/intake.
Your car should be quick. maybe not blazing fast..but faster than most normally aspirated engines.
Old Apr 3, 2002 | 03:34 PM
lex400sc's Avatar
lex400sc
thanks
Well first your nitrous is stored in a pressurized tank. Before hitting the button, you have to open the tank valves and flood the hoses. When you hit the button, another valve sprays a certain amount of nitrous oxide directly into into the cylinders with the fuel mixture.
You can't run nitrous constantly because it's too expensive and you'd have to have a 500-pound bottle in your trunk that needs constant refills. Aside from that nitrous is too potent and puts more wear on your ENTIRE engine and all moving parts within it. If you've ever seen anyone use nitrous, their tach needles fly as soon as they hit the button. Too much nitrous at a time will wreck all kinds of **** in your engine. Most people don't feed more than 150-shot into a street racer unless they are insane and value a win more than their cars (600-shot C5 guy).
I don't recommend nitrous for you if all you want is more 0-60 speed. Rarely does anyone ever use nitrous right off the line, cause most cars have enough problems with traction. The SC400 is NO exception. You'll be spinning your wheels for a few seconds trying to connect. Especially with a torque convertor added on. NOS is used a lot in higher gear, like 3rd or 4th, or wherever your drivetrain lags. On the roll it's a lot harder to break up traction.
About the exhaust, you'll gain some high end horsepower at the expense of low end torque. Because it's freer flowing exhaust you lose back pressure. Bad off the line, but good at high speeds.
Old Apr 3, 2002 | 05:30 PM
Toog4me's Avatar
Toog4me
oh yeah no doubt about it, my lex is fast... i have a feeling the guy prolly had an eaton supercharger or something like that under his hood, it was just insane though...
I dont think i would put nos in my car jus cuz your right, im not interested in doing intense streetracing right now, as i am only 16 and am driving a lexus... if i were to use nos, it would be in a supra or something more "race like".... im not only interested in 0-60 speeds, but im more interested in that than alot of other things... once i get to 60, its not hard to get to other speeds, and it would be nice to have a low qm time, but for now im set...
thanks!!!!!!!!!!!
Old Apr 3, 2002 | 05:55 PM
shroffkr's Avatar
shroffkr
Old Apr 3, 2002 | 07:50 PM
JohnnySC's Avatar
JohnnySC
that dude must have spent some serious cash to make a Yukon go that fast....considering how much it weighs
Old Apr 3, 2002 | 09:27 PM
Toog4me's Avatar
Toog4me
i have the whole shabang...
i have the maf filter adaptor and clamp along with the apexi super afc which according to importtoys, letsme take control of my intake, but i dont think it makes much of a difference.. its more of a toy...
and yeah that guy prolly has serious dough to get such a fast suv...
im gonna make a banner soon on everything in my car...
im thinking of replacing the intake with an RMM intake
Old Apr 3, 2002 | 09:47 PM
lex400sc's Avatar
lex400sc
Anthracite is selling his RMM intake if you want one. $150 I believe.
Old Apr 3, 2002 | 09:50 PM
Toog4me's Avatar
Toog4me
is it worth it? is it better than the MAF or whatever its called?
the only thing ihave left to do is get custom leather... i have a black on black so im thinking to put white (but it gets dirty too easy) or blue piping...
Old Apr 3, 2002 | 10:11 PM
abutler696's Avatar
abutler696
Toog4me: So you're 16 years old, have a 2000 SC400 with about $2000 in modifications on your car already and wanting even more.....Do your parents just hand out the cash everytime you want something else to make your car fast..........what's your trick?
Old Apr 4, 2002 | 04:35 PM
Toog4me's Avatar
Toog4me
i got a lot more than 2gs in mods if you think thats it.... im still trying to figure out how to make my own signature... im on the works of it....
my parents dont hand me cash everytime i need it... i have a cc to their account and one to my own account... they understand im a car fanatic and pay for some of the things... my stereo setup i had to pay for which includes:
2 12 inch kove audio armageddon subs in custom box
1 zapco amp (1500 watts)
1 zapco 750 watt amp
6.5 focal component set
2 1.0 farad capicatators
2 8" Kenwood touchscreens in visors
2 6.5" kenwood screens in headreasts
1 pioneer avic 9 dvd players and navagation system (has a nasty antenna and has a harddisk, so thats a plus)
Pioneer avx-p7300dvd and avm-p8000r
thats really the only stuffi paid for which i worked my *** of for... (summer job)
do most of you pay for all of your stuff and insurance, etc????
