Intermittent hesitation
Old Jun 13, 2009 | 02:44 PM
disc400's Avatar
disc400
Angry Intermittent hesitation
I am having an intermittent bucking/hestitation again on my 92 SC400. This happened a couple of months ago, and went away. This usually happens when accelerating under 2000 rpm, when the transmission changes gears but not consistently, and sometines at around 80 mph. Could this be caused by a bad cam shaft sensor?.
Old Jun 13, 2009 | 03:50 PM
over40driv's Avatar
over40driv
Have you done plugs and wires, fuel filter, air filter, checked for vacummn leaks. Prob. wouldnt hurt to do a MAF cleaning. I usually find a bottle of fuel injector cleaner will help.
Old Jun 13, 2009 | 03:57 PM
disc400's Avatar
disc400
Thanks, have not done any of those mentioned, except for Lucas or Techron, in the gas tank occasionally. Problem is so intermittent, it will run good for months, and then revert to the hesitation. Could the 10% Ethernol in the gas be an issue.
Old Jun 13, 2009 | 04:46 PM
over40driv's Avatar
over40driv
If it was I think it would do it all of the time. I always recommend brand name, highest octane gas.
Old Jun 13, 2009 | 06:26 PM
StiCk3's Avatar
StiCk3
All gasoline has been with 10% ethenol for a few years and is approved for all gasoline vehicles. i highly doubt that gas is the issue.
Old Jun 14, 2009 | 11:44 AM
disc400's Avatar
disc400
Thanks, has anyone had this issue though. The fuel filter was actually changed 6 months ago.
Old Jun 14, 2009 | 04:40 PM
shajbot's Avatar
shajbot
Does it feel like the car shift to OD prematurely and leave you with no acceleration?
Old Jun 15, 2009 | 05:26 PM
disc400's Avatar
disc400
Its like a flat spot, when accelerating between 15 and 2000 rpm, and the rev needle goes haywire, and the check engine light flashes. It somtimes happens at around 80 mph. I am leaning towards the cam shaft sensors (2). Car has 225,000 by the way, as it tends to happen when tranny shifts.
rbordeaux
Jul 18, 2018 08:58 AM
Codger07
Aug 31, 2017 07:30 PM
SgtIk3
IS - 1st Gen (2001-2005)
Aug 15, 2016 10:32 AM
rbigshow04
Feb 16, 2010 02:00 PM
RedPhoenix
Jul 29, 2009 06:10 PM
