SC400 cap/rotor question
Old Feb 20, 2009 | 02:07 AM
Ryeno's Avatar
Ryeno
Banned
Default SC400 cap/rotor question
Is it possible the remove the passenger side cap/rotor without removing the timing belt?
Old Feb 20, 2009 | 08:31 AM
ihiryu's Avatar
ihiryu
the cap and rotor as in, the ones that control the ignition? If so, then yes. The cap and rotor sits on the cam gear, all you have to do is remove the cover.
Old Feb 20, 2009 | 01:28 PM
Ryeno's Avatar
Ryeno
Banned
and how do i did that? their is a timing belt in the way.
Old Feb 20, 2009 | 01:39 PM
neurocity's Avatar
neurocity
Not quite my tempo
http://www.planetsoarer.com/penski/ThePenskiFile.html
http://www.planetsoarer.com/cambelt/cambelt.htm
Old Feb 20, 2009 | 05:41 PM
Ryeno's Avatar
Ryeno
Banned
That does not help me at all.
Old Feb 21, 2009 | 11:18 AM
xxtoobsxx's Avatar
xxtoobsxx
If your talking about a belt, its most likely the accessory belt. Just take a 19 ot 17mm cocket and use the tensioner pulley to take the belt off. The just pop the black cover off and take off the cap n rotor, I believe its 2 10mm bolts!
Old Feb 21, 2009 | 05:32 PM
LexAnt's Avatar
LexAnt
i cheated, i just pryed the cover back enough to slip in/out the rotor.
Old Feb 22, 2009 | 10:55 AM
neurocity's Avatar
neurocity
Not quite my tempo
Seriously...between those two links you cant see how they come off? You are talking about the Coils with the spark plugg wires that are right in front of the cam gear right? I mean I would call those cap'n'rotors too...Im just wondering if I'm missing something here.
Old Feb 22, 2009 | 04:14 PM
stevechumo's Avatar
stevechumo
When I rebuilt my engine, I took everything off so I couldn't recall if I had to remove the timing belt first or not. I think I removed the caps & rotors first. I don't think you'll need to remove the timing belt in order to change the caps & rotors. You can see them in the picture here that the timing belt is actually behind the caps & rotors.
Attached Thumbnails SC400 cap/rotor question-build11-copy.jpg
xshurikx
Dec 22, 2013 10:05 AM
Avery
Jul 7, 2010 05:28 PM
soarer13oy
Mar 17, 2009 10:11 PM
sc4lexus
Nov 3, 2008 06:18 AM
Quick VR-4
Oct 27, 2005 12:15 PM
