control arm bushing install.....
Old Feb 6, 2009 | 09:05 AM
surrealSC's Avatar
surrealSC
Default control arm bushing install.....
anyone know if i would be able to install the bushings myself or does it really need to be taken to a shop to have them punch it out? upper and lower fronts? rear? mine needs to be replaced asap..... is there a tool i can buy that can punch these out to save me some money instead of taking it to a shop?
if i did take it to a shop what am i looking to spend? thanks!
Old Feb 6, 2009 | 09:16 AM
93SC300.'s Avatar
93SC300.
honestyl its not complex to do it but its time consuming. i just did mine about 2 months ago and u have to burn them out. im sure u can push them out but burning is much easier and u have to clean them super good. well this was to install the daizen's. this is for the front upper and lower. i think if u take it to a shop ur easily looking between 500-1000 bucks. id do it myself. its not hard, just tiime consuming. plan on not driving ur car for a day
Old Feb 6, 2009 | 09:24 AM
Teal Sc400's Avatar
Teal Sc400
Default Control Arm Bushing
surrealSC, These links should give you a general idea of the process.
https://www.clublexus.com/forums/sus...l-arm-diy.html
https://www.clublexus.com/forums/sus...k-warning.html
Post# 42
https://www.clublexus.com/forums/sus...arm-diy-3.html
Old Feb 6, 2009 | 10:34 AM
surrealSC's Avatar
surrealSC
thanks guys! did u use a blow torch to burn it out? or oven (soften the rubber out)? also when u did the daizen install did u get the full kit(bushing and plates) .... or the the bushings itself?
Old Feb 6, 2009 | 07:52 PM
Biggu's Avatar
Biggu
why bother with daizen stuff when its over priced re badged prothane bushings.
front busings part number 18-207-bl
rear bushings part number 18-304-bl
i just started doing mine today and i ordered them from jegs. $140 some front and rears.
Old Feb 6, 2009 | 09:15 PM
FormosaSC's Avatar
FormosaSC
it cost 500-1000 to change bushings??? thats like engine swap money, you sure about this?
Old Feb 7, 2009 | 12:41 AM
surrealSC's Avatar
surrealSC
just to get this straight if i did go with daizen is it necessary to get the outer steel shells and inner sleeves or just the bushings?
as far a jegs did they come with the shells or just the bushings? pretty decent polyurethane?
Old Feb 7, 2009 | 06:49 PM
JspecSC3's Avatar
JspecSC3
It cost me about $350 to get mine done. All they used was an air hammer. Next time I'm doing this myself.
Old Feb 8, 2009 | 10:35 AM
surrealSC's Avatar
surrealSC
any idea if the shells and plates are necessary? whats its purpose?
Old Feb 9, 2009 | 10:32 PM
Ikrshinji's Avatar
Ikrshinji
I just did had my prothane kit (front and rear) installed by my mechanic. Had the TM steering rack mount bushings installed as well. He charged me 600 dollars due to the fact that he had to torch them out individually and reuse the original shell and casing. If I had the oppurtunity to go back in time, I would have purchased the daizen front kit with the new case and sleeve.
If you purchase the daizen kit with the new shell and case then you'll only need to have them press out the old one and press the new one. There are two different model numbers for the daizen kit, one with new sleeves and one without. The prothane front kit requires you use the original case and sleeve.
I too had contemplated on DIY but I could not afford the downtime.
Old Feb 10, 2009 | 06:15 PM
Matador's Avatar
Matador
They are a pain to change since you cant torch them all out. You have to at least press the ones with aluminum arms. Ideally, you would press them all out. Most shops tend to charge between 800-1000 for the service. It varies of course if you provide parts. I helped a friend do his and it was almost more trouble than it was worth between the down time, trips to the hardware store, etc. It was a fun experience, but I took mine to a shop and had it in and out in under 2 days.
Old Feb 10, 2009 | 06:24 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Daizan bushings are good so far.. I have replaced all of mine, and its not that hard. You will have to burn them out. Take your time.. Use the above links and if you need further assistance let us know. Well worth the time and money. Also, may be a good idea to change struts, mounts, and the sway bar bushings and links.. These are not much more, but well worth the time and effort. Just my 2 cents!
Old Feb 10, 2009 | 09:24 PM
dwebb99's Avatar
dwebb99
A little propane torch (same thing plumbers use to solder copper pipes) works great. $20 at Lowes. Git-er-done....
Old Feb 10, 2009 | 11:00 PM
surrealSC's Avatar
surrealSC
the plate dont usually get distroyed right? would hate to order from jegs (without the shell/plate) and after taking the bushing out that the plates are broken. ive got 108k miles on my car but putting it on reverse it chugs/squeaks pretty bad. would like to save money, daizen kit is nearly 300 from both front and back.
Old Feb 10, 2009 | 11:08 PM
huNGjaii's Avatar
huNGjaii
just out of curiosity would the torching alter the properties of the metals of the control arms? eg. making the metal weaker after the torching?
