Blown Differential
Old Dec 22, 2008 | 04:36 PM
sc250tt's Avatar
sc250tt
Default Blown Differential
I converted my 1j sc to 5 speed a couple months ago and all went well other than a loud r154. two days ago the rear started making a loud banging shrudder sound from the right rear wheel when i take off from a dead stop.
There is alot of oil leaking from the front seal of the diff also. I never had a diff blow on me so is this the signs of a blown diff?
Old Dec 24, 2008 | 06:42 AM
sc250tt's Avatar
sc250tt
nobody knows what a broken diff feels like ? .
Old Dec 24, 2008 | 03:37 PM
rwdanthony's Avatar
rwdanthony
brownmagic should know about this. im pretty sure you diff is blown...
youll have drop it out either way, why not check and post pics?
Old Dec 24, 2008 | 06:00 PM
5sp_jzz30's Avatar
5sp_jzz30
when mine blew it first started being loud and clunky and then one day taking off a dead stop it just went "bam" and the car was dead in its tracks. put it in gear and it would not do anything.
Old Dec 25, 2008 | 06:02 AM
sc250tt's Avatar
sc250tt
I thought the v8 diff would be stronger since its getting more torque compared to the ge. I guess high miles and wheel hop on first gear contributed to this. I inspected rear subframe and nothing looks loose or broken, I did a car fax and found out this car lives most of its life in the Wi and Il states so because of that the subframe is rusted bad. I and going to replace the complete rear sub assembly in a couple of weeks.
I guess i can make a writeup on how to remove the rear subframe .I am not 100% sure but i did read that the supra, sc and gs uses the same rear subframe. I will give gazi a shout to confirm this.
Thanks for the replys guys I know it was something bad, luckily i parked it before it had the chance to give out on me .Getting the car towed with a jic kit is impossible.
Old Dec 25, 2008 | 12:42 PM
5sp_jzz30's Avatar
5sp_jzz30
the diff on the sc400 and sc300 is the same as far as the housing. the difference is in the gearing. sc400 had lower gearing since it has more torque.
subframe removal is easy. im in the process of doing all my control arm bushings. i will be dropping my rear subframe tomorrow.
Old Dec 26, 2008 | 07:06 AM
dumdumgreg's Avatar
dumdumgreg
were you torsen or open diff?
Old Dec 26, 2008 | 08:59 AM
Gunnar's Avatar
Gunnar
Wheelhop kills rear end parts for sure. And yeah, better to replace the subframe while you're thinking about it than have it break on you like Black_SC did.
Look into some parts like traction bars and the FSM solid diff mounts, that should help the wheel hop a bit so you don't keep breaking stuff over and over again.
Old Dec 26, 2008 | 07:11 PM
JspecSC3's Avatar
JspecSC3
I blew a diff once. After months of abuse at the drag strip I knew the day was someday going to come. There was fluid around the diff case which is a warning sign. When you roll off a dead stop you can hear and feel a clunk in the rear. I never had to replace and sub frames. I just unbolted the axles, unbolted the driveshaft, unbolted the diff, and down came the diff.
Old Dec 27, 2008 | 08:13 AM
shonuff53's Avatar
shonuff53
wow that sucks man, a week ago I replaced my diff with a early sc400 diff and installed the trd lsd, when I went to remove my old diff I drained it first and at my surprise I found about 8 pieces of teeth about half inch long and a lot of metal bits, I was going to keep my old diff as a spare but I was so disgusted that I just threw it away. I never felt anything wrong with the diff, it was a stock diff with plus 200k of miles.
Old Dec 28, 2008 | 06:46 AM
sc250tt's Avatar
sc250tt
My upper bushings are toasted too .Which bushings are you using ? Im gonna use the prothane bushings since its a good bang for the buck .Can you snap some pics if you can. Loooking at the subframe it looks like there are 6 main bolts that has to be removed to get it out .
I think the sc have a open diff.
So i guess wheelhop killed it. It happened a couple time on first and second gear. I was shocked to see the condition of the subframe . i will definately replace it . The last thing i want to do is replace subframe after replacing the diff and bushings.
Do you have experience with the solid diff mounts? Sounds like a good investment.
This is exactly what mines sound like.
I can imagine what mines look like . My diff probablt have about 300K+ miles on it .last carfax report recorded 245K miles and that was a couple years ago .
Thanks for all the input guys, now i know for a fact its blown .Now i just have to get the time and energy to replace the rear end. I will definately do a write up on this.
Mrbolly
Performance
Apr 18, 2017 07:16 AM
Studiogeek
Oct 2, 2015 11:47 AM
ILOVEGIRLS
IS - 1st Gen (2001-2005)
May 7, 2012 10:45 PM
JDMmuscle
May 9, 2007 04:54 PM
Slow_go_400
Apr 30, 2007 10:56 AM
