Eibach installation
I am going to order my Eibach pro-kit springs some time this week and I am in question to where I could have them installed at. I was thinking about doing it myself, but I know nothing about suspension. Then I was thinking of a local tire shop, but I have head stories where the rear sway bars were incorrectly re-installed and one side of the car being 2in different than the other. Soo.... I was thinking maybe my lexus dealership could install them. I figure they wouldent skrew up the installation. Plus i am dure for an oil change in a week or so i could have them install the springs while my car is already there. Would the dealership do this? Do they install aftermarket products on their cars? Thanks for the help.
SR
Likely the lex dealer is going to tell you no. They will almost never install aftermarket parts. Try a Midas or Meinke type place. That way its a big company to go after if they break something. It's not easy to call the HQ of a garage, when Bubba did the work, and his uncle Cleatus owns the place.
SR
They have told me that they have installed Millen parts on other Lexus' as well as L-Tuned parts which were brought in by owners and not ordered thru them.
They give you an estimate of the expected labor an consumables before the work is done.
If you are having the work done by a mechanic outside of Lexus, you may want to provide the mechanic with the critical bolt torque settings. Also, if you are changing the springs, this is the opportune time to change struts if you need them. Also check out the strut boots which are rubber and protect the upper shock rod from splash.
If you do this on your own, I do suggest you get a shop manual. There is for instance, if memory serves me, a need to align the suspension after a strut / coil change. Little known fact.
If your dealer will do it, go for it! It may cost more, but you've got Lexus quality mechanics.
SR
Well I know Johnson Lexus in Raleigh, NC, and JM lexus here in southern Florida sure won't touch aftermarket parts. They wouldn't even take off my strut tower bar to change the timing belt...since it was aftermarket.
SR
Did you already order the Eibach Pro-Kit?
I will have one ready for sale once I swap my existing kit with coilovers.
I also have a set of Eibach springs for MKIV Supra.
Just letting you know.
Peter~
lex
Eibachs are excellent springs - I hear a lot of people complaining about them, but they are the ones who don't seem to understand how a suspension actually works. Either they install them improperly, or use them with the wrong strut.
I've had my Eibackl/Tokico for over 2 years now and have nothing but good things to say about them. They keep a close to stock feel. A little stiffer, but not unbearable and hardly noticable. And contrary to popular belief, my car isn't unlevel, they were a snap to install, and the springs don't bang on anything. I have NEVER bottomed out or scraped my front lip either. The car is lowered 3/4 - 1" and it isn't slammed by any sence of the term.
I like them; other may not. I knew what I was doing when I installed them; others may not. You decide what you like/need. Just make sure they are installed right the first time. If something seems hard, most likely you're doing something wrong.
Hope it helps,
Keith
I am thinking of replacing the struts myself if possible. I will give this a try before shelling out additional $200 for the shop to replace them for me.
Since you mentioned about the shop manual, I would appreciate it if you can either send/post how to replace springs/struts yourself.
Thanks in advance.
Peter
LEXO400sc,
where did you find the Eibach kits for that price? Wow, the lowest I found was around $350 and the highest price? Well over $450...
ChrisSC300,
You can find the springs at shox.com, overboost.com, optauto.com, carparts.com, etc.
I think on average, you can find one for about $75.
www.tirerack.com wanted 309.00
I'll post the procedure tommorow for the rear and the front if I have enough time
Cory
