Resetting check engine light
Old Nov 28, 2016 | 03:21 AM
twylie's Avatar
twylie
Originally Posted by 5sp_jzz30
1. pop the hood
2. remove cover from the engine bay fuse panel on the driver side fender behind the battery(2 screws)
3. locate the 30 amp EFI fuse and pull it out.
4. wait at least 10 seconds
5. replace fuse and youre good to go
Thanks! I needed to do this after I did a tune up. I started the car before replacing all the covers and intake tubes; caused the CEL and TRAC lights to come on. No issues after resetting the EFI fuse.
Old Sep 28, 2018 | 12:12 PM
dlcoffin's Avatar
dlcoffin
1. pop the hood
omg you saved me my car threw a code at me, and my efi1 fuse (20a) for my 97 Lexus ls400 did the trick! Of course I got the code read, first, so I know
Old Dec 15, 2019 | 10:30 AM
Lexanna's Avatar
Lexanna
Smile
1. pop the hood
2. remove cover from the engine bay fuse panel on the driver side fender behind the battery(2 screws) Two clips
3. locate the 30 amp EFI fuse and pull it out. 15Amp
1995 ES300 54,526 original miles --- My setup is in bold Worked great !!!! Thank YOU
Old Apr 1, 2020 | 08:57 AM
Tortilla's Avatar
Tortilla
Default Downpipe install
I had a catless downpipe installed everything went well. After driving for 3 hrs a check engine light came up. I do have a 90 degree o2 sensor spacer. I don’t want to take it to the dealership because I’m still under warranty. I drive a 2019 Lexus is300.
Old Aug 21, 2024 | 04:30 PM
Elliot2008's Avatar
Elliot2008
8th Gear
1. pop the hood
I did this to my 1995 Lexus LS400 and the CEL is still on. The code is for the TPS. Even though I've replaced both. Anyone know a solution to either fix the problem with my TPS or remove the cel? Another symptom is that when the car is in drive, it doesn't like going past 2k rpm. Almost like a rev limiter but not.
rgonza1
Mar 26, 2015 10:37 PM
2JZwannabe
Apr 29, 2012 09:39 AM
johnnybmw1
Jan 27, 2009 05:08 PM
diamondlex
Nov 2, 2006 09:43 PM
johnw
Apr 8, 2003 08:12 AM
