Need Help!! Electrical Prob!!
Old Sep 5, 2005 | 12:39 PM
diamondlex's Avatar
diamondlex
Exclamation Need Help!! Electrical Prob!!
Hi I have a 94 es300 with a kenwood dpx MP4030. Ive never had any problems with the electrical system except about a month ago the little check engine light came on which according to the manual means there is a problem with the electrical system. Everything was working fine and i didnt have the money to get it looked at so i left it. A couple days ago i started the car up and the HU came lit up and came on as usual but then shut off. I had blown a fuse so i replaced it. The new one only lasted about a minute and then blew again. I tried 1 more time and it blew again. So the next day i went out and started checking the fuses in the engine compartment and they were ok. When i started the car up the check engine light had gone off so i tried putting another new fuse in the cig/lighter spot again and it still blew after 1 minute. I think the light may have gone off because when u pull a certain fuse i think i read somewhere that it resets the light?? would the light come back on if there was still a problem?? well i dunno if i have a short or what or what to do about it so any ideas would be appreciated. can i fix this myself?? will it cost a lot to get electrical problems fixed?? thanx, Nick.
Old Sep 5, 2005 | 12:59 PM
Pheonix's Avatar
Pheonix
Cool
Power / ground to the radio is shorting, or you plugged something into the cig lighter other than the cig lighter.
The wiring that goes to the cig lighter can't pull much power, which is why it's a small fuse. The wiring is very, very easy to burn in half & when that happens, it'll normally short.
Check for shorts to the radio, and the cig lighter.
Old Sep 5, 2005 | 01:24 PM
diamondlex's Avatar
diamondlex
i had my cell charger pluged in to the cig adapter for a while im not sure if it was at the time the first fuse blew... whats a short mean? i dont know crap bout this stuff r u saying that u think the wire may have burned up to the cig lighter? with the fuse out my whole center console is out except a few lights for the a/c... i gotta get this fixed what should i do?
thanx
Old Sep 10, 2005 | 09:45 PM
Pheonix's Avatar
Pheonix
Cool
A short is what happens when you put a positive to a ground. It goes BZZZIIIIIIT and sparks, heats up & melts stuff.
I'm saying it could be melted wiring if you pulled a lot of current through the lighter. A cell phone wouldn't do it tho.
I would be the head unit power is grounding on somewhere, or making intermitant contact. Pull the deck out & check it's wiring.
Old Sep 10, 2005 | 10:13 PM
3rdelement's Avatar
3rdelement
Default lol!
"A short is what happens when you put a positive to a ground. It goes BZZZIIIIIIT and sparks, heats up & melts stuff"
BEST QUOTE EVER!
Old Nov 1, 2006 | 11:55 AM
diamondlex's Avatar
diamondlex
Talking
called sheehy lexus told me right away to check for a penny in the cig lighter... prob solved.
Old Nov 2, 2006 | 09:43 PM
Parke10's Avatar
Parke10
yep thatll do it every time
rgonza1
Mar 26, 2015 10:37 PM
oceangal98
Maintenance
Aug 27, 2012 12:07 PM
DixonPai
Sep 27, 2010 12:02 PM
Zappy
Feb 8, 2010 10:00 PM
Mr.NA_T
Jun 17, 2009 07:24 PM
