Resetting check engine light
Old Nov 27, 2008 | 01:39 PM
sc4001992's Avatar
sc4001992
Default Resetting check engine light
i was messing with my maf and tb this morning, and i went to turn it on and the check engine light was on, is there a fuse to pull to reset this or what can i do to reset this. thanks
Old Nov 27, 2008 | 01:50 PM
LEX_MAN's Avatar
LEX_MAN
Disconnect the battery for 30 seconds.
Old Nov 27, 2008 | 01:53 PM
sc4001992's Avatar
sc4001992
did that, light was still on.
Old Nov 27, 2008 | 02:00 PM
LEX_MAN's Avatar
LEX_MAN
That means you forgot to plug one of the plugs in your engine bay.
Old Nov 27, 2008 | 02:02 PM
5sp_jzz30's Avatar
5sp_jzz30
1. pop the hood
2. remove cover from the engine bay fuse panel on the driver side fender behind the battery(2 screws)
3. locate the 30 amp EFI fuse and pull it out.
4. wait at least 10 seconds
5. replace fuse and youre good to go
Old Nov 27, 2008 | 02:05 PM
sc4001992's Avatar
sc4001992
Originally Posted by 5sp_jzz30
1. pop the hood
THANK U!!!
Old Nov 27, 2008 | 04:13 PM
sc4001992's Avatar
sc4001992
****. So i did the efi fuse removal and the check engine light is still on...however it only goes on when i let off the gas...idle is good at around 500 when in drive...any ideas?
Old Nov 27, 2008 | 05:41 PM
5sp_jzz30's Avatar
5sp_jzz30
do a search on running a diagnostics test on your car. see what the codes it pulls up. if its something random and you pull the fuse and the check engine light never comes back then w/e but if its comes back soon or right away its probably something important that you should get checked out.
Old Nov 27, 2008 | 06:47 PM
FormosaSC's Avatar
FormosaSC
/\ he knows a lot
Old Nov 27, 2008 | 07:53 PM
5sp_jzz30's Avatar
5sp_jzz30
^^^ thanx 1sickSC
i know a few things
Old Nov 27, 2008 | 09:32 PM
sc4001992's Avatar
sc4001992
Thanks for the replys. also noticed that when i turn on the ac the cars idle jumps to 1k then when i turn off the ac the car dies completely.
Old Nov 27, 2008 | 09:36 PM
TLDriver's Avatar
TLDriver
when you were messing with your maf and tb you didn't touch the wire/heating element (I am unsure how these cars have the MAF) on the maf did you? or spray anything on it? if so you might want to try some MAF cleaner on it.
Old Nov 27, 2008 | 09:51 PM
sc4001992's Avatar
sc4001992
didnt touch or spray it. Looked clean. Ill try that first. Just weird to me how the light only goes on when ilet off the gas.
Old Nov 29, 2008 | 12:53 AM
sc4001992's Avatar
sc4001992
sprayed the maf with maf cleaner, reset the battery.....cel still only comes on when im off the gas and the car seems to stumble a lil bit off the line or at lower rpms between 500-2k
Old Aug 18, 2009 | 10:57 PM
edz8386's Avatar
edz8386
1. pop the hood
This worked great! Thanks.
