Cheap intake solution!
Old Nov 17, 2008 | 10:46 PM
  #31
dumdumgreg's Avatar
dumdumgreg
Originally Posted by Teflon Don
Another great thing about this piping is it never loses its radius. You can turn and twist any way you want and it remains 4inch/3inch etc.
what the brand name or official name of it?
I don't see any on fleabay at the moment
Old Nov 17, 2008 | 11:09 PM
  #32
turbodremz's Avatar
turbodremz
FTW= For The Win
Old Nov 17, 2008 | 11:11 PM
  #33
rwdanthony's Avatar
rwdanthony
you can get something very similar at homedepot. its made out of aluminum. and is just the same type of tube. i can take a pic of mines later on tomarrow and show you. i think they use it for dryers.
Old Nov 18, 2008 | 01:31 AM
  #34
Teflon Don's Avatar
Teflon Don
this is the UK supplier i got it from:
http://cgi.ebay.co.uk/COLD-AIR-FEED-...1%7C240%3A1318
Be careful of the alu stuff. Make sure its not the thin stuff that can rip between the wire.
goodluck
Old Nov 18, 2008 | 12:54 PM
  #35
rwdanthony's Avatar
rwdanthony
what wire? lol sorry
Old Nov 18, 2008 | 01:00 PM
  #36
Teflon Don's Avatar
Teflon Don
essentially the piping is a big coil of wire(like a spring) with whatever material laid over it.
Old Nov 18, 2008 | 01:12 PM
  #37
rwdanthony's Avatar
rwdanthony
ohh haha yeah, its liek coiled/wraped all together. i know what you mean.
Old Jan 8, 2009 | 09:58 AM
  #38
johnnybmw1's Avatar
johnnybmw1
I guess OP never came back with the pictures like he promised...lol
I might want to do that set up with the duct suction using home depot's tubes.
product.sc , where did you get your Intake from? the same set up as OP??
does yours have any turbo sound or ROARING sound or what?
Old Jan 8, 2009 | 11:03 AM
  #39
OneJay's Avatar
OneJay
Well here's a pic from when I had mine. Great piece of work for cheap!
Old Jan 7, 2010 | 12:49 PM
  #40
Oreally480's Avatar
Oreally480
Grabbed this quote from a member on here who has a friend that did an analysis on a few well known brands of air filters.
A K&N (and those green ones out there) air filter uses 4 ply media while the S&B uses 8 ply media. The problem with the K&N is that it does not flow more air than a good aftermarket filter. If you take like a Wix racing filter or any of the other performance dry filters they all flow roughly the same amount of air (enough to make the hp you're looking for). Now, if you take a stock replacement filter, yes, the K&N is going to flow better because the OEM filter is designed to stop everything, not make horsepower. The first time you use the K&N it does not stop as much dirt as the other filters, and every time you clean it that gets worse and worse. To the point that if you clean it 4 times it's just plain pathetic. (The S&B was withing .1% after the 4th cleaning compared to when new). The media actually tears allowing particles through. Here's something to think about too. It's not the particles you can see that the air filter is stopping. It's the stuff you can't see that's going to hurt the engine.
Philsogood
Feb 20, 2016 02:28 PM
hamooduae
IS F (2008-2014)
25
May 10, 2014 11:12 PM
reyoasian
Nov 14, 2012 01:32 PM
92sc3forme
Sep 28, 2008 07:59 PM
sdpq
Performance
Feb 10, 2007 06:14 PM
