Upgrading Intake To Cone Filter
Old Sep 26, 2008 | 07:16 PM
92sc3forme's Avatar
92sc3forme
Default Upgrading Intake To Cone Filter
Hey guys, dont really have money to spend on an intake.
Was looking into expanding my airbox into a BFI intake
But was wondering would it be beneficial to remove the stock airbox at the MAF sensor, get an adaptor and replace it with a very large cone filter possibly facing down with an elbow attachment.
or would i just be better off with my stock box?
any and all constructive input is well appreciatied
Old Sep 26, 2008 | 07:43 PM
93sc3005sp's Avatar
93sc3005sp
turbonator, i got 22rwhp
Old Sep 26, 2008 | 08:15 PM
92sc3forme's Avatar
92sc3forme
Thats kinda off the direct subject but at least its a reply, i was actually talking about removing the stock airbox and having a large cone filter to replace it and the matter of if it would have any positive benefit.
on another note that turbonator sounds like a load, seems like it would be more restrictive than anything
Old Sep 26, 2008 | 10:29 PM
cbrasian's Avatar
cbrasian
I require proof and a description on what it is and see the numbers and do testing b4 i believe that......general rule of thumb you won't make much if any hp off of an intake unless you sucking in a larger volume of cold air....if you modded the airbox and prevented the intake from sucking in hot air then you would be ok....best thing is duct work to channel more cold air to it .....
Old Sep 26, 2008 | 10:37 PM
turbodremz's Avatar
turbodremz
off of an intake? no...dyno sheets with video MIGHT make someone belive that..+22 rwhp would mean atleast a +35hp gain at the crank...
Old Sep 27, 2008 | 12:24 AM
TheMole's Avatar
TheMole
I'm gonna give you the benefit of the doubt and say you're being sarcastic.
Old Sep 27, 2008 | 08:01 AM
rwdanthony's Avatar
rwdanthony
im also stuck on the decision on an intake mod for my sc, i would go with the injen but its a bit costly for my wallet. as now i have a bunch of sheet metal and plastc i can form, im going to make a cold air wind tunnel from the front of the car routed to the intake box. not sure what im going to do yet.. unless im just gonna extend the intake pipe still using the MAF and then having a cone filter down next to the bumber wind hole. ill have to get a hydro lock though forsure.
...does anyone know how a hydro lock works? and if i can make it myself?
http://www.aempower.com/ViewCategory.aspx?CategoryID=20
Old Sep 27, 2008 | 08:43 AM
Curry's Avatar
Curry
CL Folding 25,000
On an SC400 with a BFI and SAFCII you'd probably gain the 22hp, i think its actually been done and documented as well... but on an SC3? I want some of what your smoking.
Old Sep 27, 2008 | 12:41 PM
TheMole's Avatar
TheMole
A hydrolock? Hydrolock is when your engine sucks up too much water and locks up. Maybe you meant the aem bypass valve since you provided a link for it. From experience, you lose some gains with the bypass valve installed.
Look into the BFI as it has been tested and proven to provide gains without the risk of hydrolock. Also, you might want to move your license plate to the driver's side if going with the BFI.
Old Sep 27, 2008 | 07:53 PM
rwdanthony's Avatar
rwdanthony
haha yeah i thats what i meant, sorry im slow in the morning hmm but i guess i wont go witha bypass valve anymore. but also its an old pic... i dont run a front license plate anymore thanks for the heads up on the info though!
Old Sep 27, 2008 | 10:30 PM
93sc3005sp's Avatar
93sc3005sp
yea i was oviously kidding about the worderfull turbonator, i have a cone filter right where the airbox used to be and i noticed that power and everything is the same, except that theirs this cool whitsle from 5000-6800 rpm's
Old Sep 28, 2008 | 10:38 AM
92sc3forme's Avatar
92sc3forme
yeah wouldnt expect any increase in power but what about throttle response?
Old Sep 28, 2008 | 11:39 AM
93sc3005sp's Avatar
93sc3005sp
all it does is make noise
Old Sep 28, 2008 | 07:59 PM
rwdanthony's Avatar
rwdanthony
wow you have to go up to 5k just to hear your car wistle, i rather stay at 2k and hear my exhuast roar deep. lol [no criticism btw]
iloveGS4xx
Apr 22, 2010 12:46 PM
UT-ISF
IS F (2008-2014)
17
Nov 8, 2009 05:54 PM
sdpq
Performance
Feb 10, 2007 06:14 PM
lexusgy
Oct 16, 2002 08:45 PM
